08-07-2013, 19:26 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: IN {HUMEN}WORLD
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | samsung i9100 dead boot repair with riff jtag plz help me i have samsung i9100 during firmware upgrade failed and now phone is dead when i connect usb cable it asked for driver (s5pc210 test b/d ) plz where can i download this driver and plz give me correct test piont pin out for boot repairing with RIFF JTAG i where can download all models pinout for riif jtag and this driver s5pc210 test b/d |
08-07-2013, 22:30 | #3 (permalink) |
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | riff team plz tell me this s5pc210 test b/d driver where can i download when i connect usb cable pc asked this driver and phone not connect show this error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.36, JTAG Manager Version: 1.50 Selected Resurrector: [Samsung I9100 V1.0.4850.415] Connecting to the dead body...FAILED None is detected. |
08-07-2013, 22:36 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You need : 1-Check soldered Jtag Wires 2-Connect 20pin Ribbon to RIFF-Box 3-Connect USB Cable To Phone 4-Connect Battrey or Power Supply To Phone 5-Select 8 MHZ Speed At TCK 6-Press "Resurrect" --- If you have any other problem,you can contact me via sonork,,,I can teach you via Remote -- Welcome to RIFF World |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
08-07-2013, 23:08 | #5 (permalink) |
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | plz tell me if phone asked for driver when connect usb cable( s5pc210 test b/d ) ignore this or intall driver all wires are solded good |
08-08-2013, 02:35 | #6 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Brisbane, Australia
Member: 1788854 Status: Offline Sonork: Mobile Fix Simple Thanks Meter: 16 | Hi mate, just ignore the driver. Please check that it is in TCK not RTCK. I always use 4Hz for unbricking. Hope this helps. |
08-08-2013, 09:06 | #7 (permalink) |
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | plz help not connected Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.36, JTAG Manager Version: 1.50 Selected Resurrector: [Samsung I9100 V1.0.4850.415] Connecting to the dead body...FAILED None is detected. |
The Following User Says Thank You to shakeel145 For This Useful Post: |
08-08-2013, 09:15 | #8 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
http://forum.gsmhosting.com/vbb/f634...ml#post9571499 i had repaired successfully this phone without any problems.. b.r. | |
08-08-2013, 11:51 | #11 (permalink) |
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | i am using this pinout or this is ok 11 9 7 5 3 1 12 10 8 6 4 2 3 TRST 4 TDI 5 TMS 6 TCK 7 NRST 8 TDO 11 GND plz help me team |
08-08-2013, 16:24 | #13 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Philippines
Member: 235905 Status: Offline Sonork: 100.1580742:mamomogon03 Thanks Meter: 145 | same here... I soldered many times and ensure solder is good but cannot find the target... Im suspect the box hardware is not good. How to know that box is faulty? I can read box info and update box ok.... any chance it is faulty? |
