11-05-2014, 13:43 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: In Apple Device
Member: 638481 Status: Offline Sonork: 100.1601053 Thanks Meter: 749 | Samsung I9100 Error ??? Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.82V, TCK Frequency is 100 kHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x03010043 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
11-05-2014, 13:44 | #2 (permalink) |
Member: 638481 Status: Offline Sonork: 100.1601053 Thanks Meter: 749 | Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.82V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
