08-05-2012, 21:06 | #31 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
so its mean every single phone has ic problem? Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung i9100 V1.0.4582.4854] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VIS00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VIS00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3E (0x007FFF <> 0x010000) | |
08-10-2012, 19:57 | #32 (permalink) |
Registered User Join Date: Oct 2005 Location: e g y p t Age: 43
Member: 194178 Status: Offline Sonork: 100.1594302 Thanks Meter: 34 | i do all of that but cant repair phone Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung N7000 AP V1.0.4458.16492] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 100 kHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3E (0x007FFF <> 0x010000) |
08-11-2012, 19:26 | #33 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Saudi Arabia
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung N7000 AP V1.0.4458.16492] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body...OK Resurrection complete! what about this. phone still dead no errors. best regards. |
08-11-2012, 20:44 | #35 (permalink) |
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | my phone is resurrection completed 100% without any error. after that no download mode or any thing. i have do all the steps u mentioned in your post but the result is same. any help thanks & regards. Last edited by BABAK NURI; 08-11-2012 at 23:44. Reason: No Need "quote" First Post |
08-27-2012, 14:22 | #36 (permalink) | ||
No Life Poster Join Date: Nov 2008
Member: 901472 Status: Offline Thanks Meter: 48 | Quote:
BR | ||
08-31-2012, 21:17 | #38 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 621455 Status: Online Sonork: key4unlock Thanks Meter: 118 | can u explain which model u have done with this procedure many of us have same issue with i9100 and N7000 even me have same problem in N7000 nothing help with this procedure ......... it will b very helfull to others if u explain it clearly thank you |
09-01-2012, 20:43 | #40 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: india Age: 47
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | Quote:
is your problem solved or not........ | |
09-02-2012, 07:54 | #41 (permalink) |
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung N7000 AP V1.0.4458.16492] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body...OK Resurrection complete! best regards. |
09-02-2012, 10:13 | #42 (permalink) |
Junior Member Join Date: May 2009
Member: 1028687 Status: Offline Thanks Meter: 1 | Thanks a lot for your help,it test ok for me .[IMG]http://b106.photo.store.qq.com/psb?/d91c2079-a1e4-4791-b054-d6d750a77a7c/ikjoSs4Gs6wBzix*.M3BF.VXBQv4kFzLqXTA8TBQrHA!/b/dHV0ND9LLQAA&bo=ngIFAb4![/IMG] http://b103.photo.store.qq.com/psb?/...QAA&bo=FAJfAm0! |
09-20-2012, 02:55 | #44 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
if resurrector can done,but not start DL_Mode,it's means fault eMMC Chip But if error on 100%,You can extract original i727.tar file and use boot.bin | |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
Upload / Download eeprom program for 51xx/61xx | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-07-1999 14:03 |
