11-07-2013, 11:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Samsung P3100 Resurrection done but not alive? BR. Siddeque |
11-08-2013, 01:15 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Guys @ .:MobileLife:. if you need help,We Need Check Your Log ...So,Please Post Full Resurrection Log @ CHAUDHRAY ARSHAD P3100.dll Only Support 8GB eMMC But as i Can Remember ,I Tell Everyone Who Have 16Gb For Contacting me Via ICQ....But at This Time Never Contact Me Anyone - Anyway,,,We Can Repair Your Phone (if not have eMMC or HW Problem)...So,Please Contact Me Via ICQ Thanks |
11-08-2013, 06:32 | #4 (permalink) | |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
BR. Siddeque | |
11-10-2013, 11:14 | #5 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
11-12-2013, 14:22 | #6 (permalink) | |
After write full dump same problem. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [Samsung P3100 XLoader+ V1.0.4800.44817] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is 8 MHz Settings Code: 0x22010B00000000000000000010000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0100/0x0015 (MAG2GA, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0100/0x0015 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) Writting FLASH1 memory from 0x000000000000 to 0x00000FFFFFFF Completed in 02:13:56.064 (Average Transfer Rate: 32.62 kB/s) BR. siddeque | |
01-16-2015, 06:47 | #9 (permalink) |
Crazy Poster Join Date: May 2011 Location: Cavite, Phil.
Member: 1573869 Status: Offline Thanks Meter: 0 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung P3100 XLoader+ V1.0.4800.44817] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0100/0x0015 (MAG2GA, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0100/0x0015 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) No Resurrection Data is available for the eMMC Chip with Capacity = 14.68GB WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 7.28GB Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x27 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000001800000 same here |
