05-01-2013, 13:44 | #16 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | this me again try with last update Phone is alive,but stuck in factory mode. can't write custom recovery can't write custom kernel can't change cdma nv values. Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung R530 V1.0.4856.64556] Connecting to the dead body...OK Detected dead body ID: 0x406B10E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MBG8FB, 0x000747C00000 Bytes = 29.12 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MBG8FB, 0x000000200000 Bytes = 2.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 29.12GB Flashing the dead body...OK Resurrection complete! opening eMMC plugin Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung R530 V1.0.4856.64556] Connecting to the dead body...OK Detected dead body ID: 0x406B10E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x25020000000000000000000000200000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MBG8FB, 0x000747C00000 Bytes = 29.12 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MBG8FB, 0x000000200000 Bytes = 2.00 MB) Reading FLASH1 address space from 0x000000000000 to 0x0000000001FF ERROR: Failed to unpack received data. Terminating. Jtag manager ver. 1.49 Pinout use Samsung T999 there is another way to write boot rom ? |
05-01-2013, 13:57 | #17 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | with old version Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung SPH-L710 V1.0.4714.55098] Connecting to the dead body...OK Detected dead body ID: 0x406B10E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x25020000000000000000000000200000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (MBG8FB, 0x000747C00000 Bytes = 29.12 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (MBG8FB, 0x000000200000 Bytes = 2.00 MB) Reading FLASH1 address space from 0x000000000000 to 0x0000000001FF Completed in 00:00:00.031 (Average Transfer Rate: 67650064.48 kB/s) Reading FLASH1 address space from 0x000000004400 to 0x0000000045FF Completed in 00:00:00.015 (Average Transfer Rate: 139810133.27 kB/s) Reading FLASH1 address space from 0x000000000000 to 0x0000000001FF Completed in 00:00:00.031 (Average Transfer Rate: 677.42 kB/s) Reading FLASH1 address space from 0x000000004400 to 0x0000000053FF Completed in 00:00:00.062 (Average Transfer Rate: 338.71 kB/s) Analizing the FullImage File...OK Current Phone/Image File has PIT Structure. PIT Descriptor: COM_TAR2MSM8960 Total quantity of listed partitions: 27 |
05-01-2013, 14:07 | #18 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | with old version write boot Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung R530 V1.0.4856.64556] Connecting to the dead body...OK Detected dead body ID: 0x406B10E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x25020000000000000000000000200000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MBG8FB, 0x000747C00000 Bytes = 29.12 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MBG8FB, 0x000000200000 Bytes = 2.00 MB) Writting FLASH1 memory from 0x000004000000 to 0x00000401FFFF Completed in 00:00:01.125 (Average Transfer Rate: 113.78 kB/s) Writting FLASH1 memory from 0x000004020000 to 0x00000405FFFF Completed in 00:00:02.016 (Average Transfer Rate: 126.98 kB/s) Writting FLASH1 memory from 0x000004060000 to 0x0000040DFFFF Completed in 00:00:04.125 (Average Transfer Rate: 124.12 kB/s) Writting FLASH1 memory from 0x0000040E0000 to 0x0000042DFFFF Completed in 00:00:14.938 (Average Transfer Rate: 137.10 kB/s) Writting FLASH1 memory from 0x0000042E0000 to 0x00000435FFFF Completed in 00:00:03.047 (Average Transfer Rate: 168.03 kB/s) Writting FLASH1 memory from 0x000004360000 to 0x000004D5FFFF Completed in 00:01:22.282 (Average Transfer Rate: 124.45 kB/s) Writting FLASH1 memory from 0x000004D60000 to 0x000004DDFFFF Completed in 00:00:03.438 (Average Transfer Rate: 148.92 kB/s) |
05-14-2013, 19:17 | #19 (permalink) | |
Freak Poster Join Date: Sep 2009
Member: 1129443 Status: Offline Thanks Meter: 3 | problem with r530 Qualcomm HS-USB QDLoader 9008 hi i make jtag for Samsung galaxy S3 R530 here log: Quote:
phone was damage wtrying to change firmware.. | |
06-12-2013, 16:21 | #22 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Bucharest,Romania Age: 46
Member: 5204 Status: Offline Thanks Meter: 35 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung R530 V1.0.4856.64556] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x706B10E1 - IGNORED! Set I/O Voltage reads as 1.82V, TCK Frequency is 4 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG4FB, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG4FB, 0x000000200000 Bytes = 2.00 MB) No Resurrection Data is available for the eMMC Chip with Capacity = 14.68GB WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 29,12GB Flashing the dead body...OK Resurrection complete! All goes well but no download. Should there be any difference since it is a larger memory ? I also wrote the files in this post but same result. |
12-09-2013, 09:59 | #26 (permalink) |
Junior Member Join Date: Oct 2006
Member: 366472 Status: Offline Thanks Meter: 0 | I repair my r530u using boot files from 9th post? but my phone lost EFS. After many attempts to repair imei, root, flashing and other things I bricked my device. But now after flashing boot it's worcking. Maybe new version of samsung firmware makes anithyng wrong with boot area? |
12-21-2013, 15:42 | #28 (permalink) | |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | Quote:
thank you br, s1emens | |
01-22-2014, 20:58 | #30 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2090961 Status: Offline Thanks Meter: 0 | Did anyone solved this issue? I really need help for i530U. I tried the Sl1, Sl2, Aboot, boot, etc in EMMC but no luck. the phone does not turn on. But my pc recognize a device. A phone... Please help. |
