06-29-2011, 18:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | samsung s5830 not done Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [Samsung S5830] Connecting to the dead body...OK Detected dead body ID: 0x303C10E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip ID: 0xAAAA/0xAAAA (256MB) Detected a Not Initialized FLASH2 Chip ID: 0xAAAA/0xAAAA (256MB) ERROR: Selected FLASH Chip was not initialized by the DCC Loader. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [Samsung S5830] Connecting to the dead body...OK Detected dead body ID: 0x303C10E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip ID: 0xAAAA/0xAAAA (256MB) Detected a Not Initialized FLASH2 Chip ID: 0xAAAA/0xAAAA (256MB) ERROR: Selected FLASH Chip was not initialized by the DCC Loader. chk on all speeed same error phone new brand bricked in unbranding plz help thnx in advance |
07-08-2011, 22:33 | #3 (permalink) |
Registered User Join Date: May 2006
Member: 276877 Status: Offline Thanks Meter: 0 | Hi, i also need help. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [Samsung S5830] Connecting to the dead body...OK Detected dead body ID: 0x303C10E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip ID: 0xAAAA/0xAAAA (256MB) Detected a Not Initialized FLASH2 Chip ID: 0xAAAA/0xAAAA (256MB) ERROR: Selected FLASH Chip was not initialized by the DCC Loader. Thnx in advance. |
07-09-2011, 12:11 | #4 (permalink) |
Member: 276877 Status: Offline Thanks Meter: 0 | Detected dead body ID: 0x303C10E1 - IGNORED! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0050 (512MB) Writting FLASH1 memory from 0x00000000 to 0x1FFFFFFF Completed in 01:02:22.328 (Average Transfer Rate: 144.47 kB/s) firmware full (dll I5500) did not help. |
07-13-2011, 13:30 | #7 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Use these files til we prepare bugfix update. Index of /downloads/s5830 There is two screenshot with settings and full backup, You need to write boot files to phone from two ad*******, according to settings on screenshots. Be carefully, of course. |
The Following User Says Thank You to legija For This Useful Post: |
07-14-2011, 14:09 | #10 (permalink) |
Member: 276877 Status: Offline Thanks Meter: 0 | Insertion of the ad******* did not help. Help full. Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0050 (512MB) Writting FLASH1 memory from 0x00000000 to 0x1FFFFFFF ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK Completed in 01:13:22.156 (Average Transfer Rate: 122.82 kB/s) |
10-18-2012, 13:44 | #12 (permalink) |
No Life Poster Join Date: Aug 2004 Location: india Age: 51
Member: 78028 Status: Offline Thanks Meter: 90 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung S5570 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip, ID: 0xAAAA/0xAAAA (256MB) ERROR: Selected FLASH Chip was not initialized by the DCC Loader. thanks in advance. |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
