Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 11-06-2012, 15:49   #1 (permalink)
MOHIT_THAREJA's Avatar
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
samsung s5830i download mode not come
set problem is main menu is blank
i try to resurrection but same problem download mode not mode when i press download mode key
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.34, JTAG Manager Version: 1.45
Selected Resurrector: [Samsung S5830i V1.0.4476.13359]
Connecting to the dead body...OK
Detected dead body ID: 0x07B3617F - CORRECT!
Set I/O Voltage reads as 2.99V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
Selected Resurrection Data for the NAND Chip with Page size = 4KB
Flashing the dead body...OK
Resurrection complete!
Old 11-06-2012, 15:54   #2 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 572
write full dump to phone. again what happend before resurrection was phone working before killed by software?
Old 11-06-2012, 16:00   #3 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 537
try with USB JIG..................
Old 11-06-2012, 20:44   #4 (permalink)
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
my phone is on network is not come and menu is not open
when i try wipe wipe complete but set is not wiping means data is not delete.
and set is also not come with download mode that why i cant flash with flasher
then i try to restruction with but same prob download mode is not come
Old 11-06-2012, 20:48   #5 (permalink)
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
can some one tell me if i erase the set with riff then write full dump
can i repair imei with z3x or riff
Old 11-08-2012, 09:58   #6 (permalink)
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
problem solved
Settings Code: 0x27010009000000000000000020000000
Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED
The DCCLoader USB Interface is not found. Communication continues over the DCC Interface
Resuming write FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF on 0x0000096C0000
Completed in 01:04:55.937 (Average Transfer Rate: 138.78 kB/s)
Old 03-17-2015, 10:34   #7 (permalink)
Member: 1971574
Sonork: 1658087
Thanks Meter: 4
hi i have samsung s5830i its not going to download mode with i9100 urt jag but it show blue display nothing show other and not work with keys method .
so plez any body can help me PLEZZZZZZZzzz
Old 04-15-2015, 11:04   #8 (permalink)
Member: 2235775
Thanks Meter: 124
i am successful s5830i enter download mode
i am successful s5830i enter download mode.
1)remove battery & press vol up + down then insert usb to pc.
then attach battery
3)now show pc device manager samsung phone
now working flashing by odin & other
The Following 4 Users Say Thank You to alorpothe For This Useful Post:
Old 04-23-2015, 14:25   #9 (permalink)
Member: 1941129
samsung s5830i download mode successful
then attach battery
thanksssssss...itsss 100% working
Old 05-21-2015, 04:39   #10 (permalink)
Member: 1557968
Sonork: 1659614
Smile
then attach battery
good solution its work for me_____thnxxxxxxx
Old 06-13-2015, 17:26   #11 (permalink)
..::KASHIF::..'s Avatar
Member: 1294044
Thanks Meter: 1,169
then attach battery
sahzada 100000% Working
Old 06-29-2015, 23:23   #12 (permalink)
Member: 2207038
Thanks Meter: 2
thanks for help................................
The Following User Says Thank You to hyder tanveer For This Useful Post:
Old 09-02-2015, 13:59   #13 (permalink)
..:::GSM CLUB™:::..'s Avatar
Member: 859030
Sonork: 100.1619336
Thanks Meter: 310
then attach battery
thanks for great solution
Old 09-20-2015, 06:23   #14 (permalink)
Member: 1453246
Thanks Meter: 2
thnks ...........................
Old 09-27-2015, 10:00   #15 (permalink)
Member: 2420187
thanaks alopr nice job for 5830i
Page generated in 0.38849 seconds with 7 queries
