samsung shv-e160L hangs on logo after resurrection and dump writing
samsung shv-e160L had camera problem, got dead on flashing.
resurrection ok Quote:
[3/31/2016 10:22:13 AM] [START OPERATION_ID = RESURRECT]
[3/31/2016 10:23:26 AM] Open serial port...OK
[3/31/2016 10:23:26 AM] Connecting to the RIFF Box...OK
[3/31/2016 10:23:26 AM] Firmware Version: 1.37, JTAG Manager Version: 1.56
[3/31/2016 10:23:26 AM] Selected Resurrector: [Samsung E160L V1.0.4637.58162]
[3/31/2016 10:23:26 AM] Connecting to the dead body...OK
[3/31/2016 10:23:26 AM] Detected dead body ID: 0x105310E1 - CORRECT!
[3/31/2016 10:23:26 AM] Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK
[3/31/2016 10:23:26 AM] Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz]
[3/31/2016 10:23:26 AM] Resurrection sequence started.
[3/31/2016 10:23:26 AM] Establish communication with the phone...OK
[3/31/2016 10:23:26 AM] Initializing internal hardware configuration...OK
[3/31/2016 10:23:26 AM] Uploading resurrector data into memory...OK
[3/31/2016 10:23:26 AM] Starting communication with resurrector...OK
[3/31/2016 10:23:26 AM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (KTS00M, 0x0003AB400000 Bytes = 14.68 GB)
[3/31/2016 10:23:26 AM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (KTS00M, 0x000000200000 Bytes = 2.00 MB)
[3/31/2016 10:23:26 AM] Flashing the dead body...OK
[3/31/2016 10:23:26 AM] ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK
[3/31/2016 10:23:26 AM] Resurrection complete!
[3/31/2016 10:23:26 AM] [FINISH OPERATION_ID = RESURRECT] |
Dump writing ok Quote:
[3/31/2016 11:47:20 PM] [START OPERATION_ID = DCC_WRITE_MEMORY]
[3/31/2016 11:47:20 PM] Current Settings:
[3/31/2016 11:47:20 PM] -----------------
[3/31/2016 11:47:20 PM] Address: 000000000000
[3/31/2016 11:47:20 PM] Length: 000020000000
[3/31/2016 11:47:20 PM] Address Space: ROM1
[3/31/2016 11:47:20 PM] AutoFullFlash: UNCHECKED
[3/31/2016 11:47:20 PM] Use End Address: UNCHECKED
[3/31/2016 11:47:20 PM] ECC Module Enabled: UNCHECKED
[3/31/2016 11:47:20 PM] Image File is Used: UNCHECKED
[3/31/2016 11:47:20 PM] Use Address as Offset: UNCHECKED
[3/31/2016 11:47:20 PM] Main (CHECKED): C:\Users\man\Desktop\n7000\SHV-E160L_Work_Dump_FA09.bin
[3/31/2016 11:47:20 PM] Redu (UNCHECKED):
[4/1/2016 2:17:27 AM] Open serial port...OK
[4/1/2016 2:17:27 AM] Connecting to the RIFF Box...OK
[4/1/2016 2:17:27 AM] Firmware Version: 1.37, JTAG Manager Version: 1.56
[4/1/2016 2:17:27 AM] Selected Resurrector: [Samsung E160L V1.0.4637.58162]
[4/1/2016 2:17:27 AM] Connecting to the dead body...OK
[4/1/2016 2:17:27 AM] Detected dead body ID: 0x105310E1 - CORRECT!
[4/1/2016 2:17:27 AM] Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK
[4/1/2016 2:17:27 AM] Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz]
[4/1/2016 2:17:27 AM] Settings Code: 0x20010009000000000000000020000000
[4/1/2016 2:17:27 AM] Resurrection sequence started.
[4/1/2016 2:17:27 AM] Establish communication with the phone...OK
[4/1/2016 2:17:27 AM] Initializing internal hardware configuration...OK
[4/1/2016 2:17:27 AM] Uploading resurrector data into memory...OK
[4/1/2016 2:17:27 AM] Starting communication with resurrector...OK
[4/1/2016 2:17:27 AM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (KTS00M, 0x0003AB400000 Bytes = 14.68 GB)
[4/1/2016 2:17:27 AM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (KTS00M, 0x000000200000 Bytes = 2.00 MB)
[4/1/2016 2:17:27 AM] Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF
[4/1/2016 2:17:27 AM] Completed in 02:30:06.063 (Average Transfer Rate: 58.22 kB/s)
[4/1/2016 2:17:27 AM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY]
how to recover it please
