04-09-2018, 11:14 | #1 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2591572 Status: Offline Thanks Meter: 0 | Samsung SM-G318H EMMC fail. I have RIFF v1 and an adapter (like this https://multi-com.eu/,details,id_pr,...ox-rc1000.html) First connection and I get this: [2018-03-29 11:51:30] [START OPERATION_ID = 26] [2018-03-29 11:51:30] Open serial port...OK [2018-03-29 11:51:30] Connecting to the RIFF Box...OK [2018-03-29 11:51:30] Firmware Version: 1.49 (RIFFBOX1), JTAG Manager Version: 1.76 [2018-03-29 11:51:30] [2018-03-29 11:51:30] Connecting to the SD/eMMC Card...OK [2018-03-29 11:51:30] Set I/O Voltage reads as 2.70V, SD_CLK Frequency is 2.50 MHz [2018-03-29 11:51:30] [2018-03-29 11:51:30] Memory Type .......................... eMMC [2018-03-29 11:51:30] Manufacturer ID ...................... 0x90 [2018-03-29 11:51:30] OEM/Application ID ................... 0x4A [2018-03-29 11:51:30] Product Name ......................... "H4G2b " [2018-03-29 11:51:30] Package .............................. BGA [2018-03-29 11:51:30] User Area Partition Size ............. 0x0000E9000000 Bytes (3.64 GB) [2018-03-29 11:51:30] Boot Partition Size .................. 0x000000400000 Bytes (4.00 MB) [2018-03-29 11:51:30] RPMB Partition Size .................. 0x000000400000 Bytes (4.00 MB) [2018-03-29 11:51:30] OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity) [2018-03-29 11:51:30] Write Protection Bits ................ NONE [2018-03-29 11:51:30] ExtCSD Register Fields ............... [177] = 0x00, [179] = 0x08, [162] = 0x00 [2018-03-29 11:51:30] Boot Configuration ................... Boot from Boot Partition 1 (Bus Width = 1Bit) [2018-03-29 11:51:30] Chip Revision ........................ 0.1 [2018-03-29 11:51:30] Multimedia Card Revision ............. 1.6 (eMMC v4.5, v4.51) [2018-03-29 11:51:30] Serial Number ........................ 0x26CA984D [2018-03-29 11:51:30] Memory Manufacturing Date ............ October, 2015 [2018-03-29 11:51:30] [FINISH OPERATION_ID = 26] I started to read but it hung after few minutes and after restart I get this: [2018-03-29 12:22:02] [START OPERATION_ID = 26] [2018-03-29 12:22:02] Open serial port...OK [2018-03-29 12:22:02] Connecting to the RIFF Box...OK [2018-03-29 12:22:02] Firmware Version: 1.49 (RIFFBOX1), JTAG Manager Version: 1.76 [2018-03-29 12:22:02] [2018-03-29 12:22:02] Connecting to the SD/eMMC Card...OK [2018-03-29 12:22:02] Set I/O Voltage reads as 2.79V, SD_CLK Frequency is 2.50 MHz [2018-03-29 12:22:02] [2018-03-29 12:22:02] Memory Type .......................... eMMC [2018-03-29 12:22:02] Manufacturer ID ...................... 0x65 [2018-03-29 12:22:02] OEM/Application ID ................... 0x6F [2018-03-29 12:22:02] Product Name ......................... "M MOR " [2018-03-29 12:22:02] Package .............................. Removable [2018-03-29 12:22:02] User Area Partition Size ............. 0x000075700000 Bytes (1.83 GB) [2018-03-29 12:22:02] Boot Partition Size .................. 0x000000200000 Bytes (2.00 MB) [2018-03-29 12:22:02] RPMB Partition Size .................. 0x000000020000 Bytes (128.00 KB) [2018-03-29 12:22:02] OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity) [2018-03-29 12:22:02] Write Protection Bits ................ NONE [2018-03-29 12:22:02] ExtCSD Register Fields ............... [177] = 0x00, [179] = 0x78, [162] = 0x00 [2018-03-29 12:22:02] Boot Configuration ................... Boot from User Area (Bus Width = 1Bit) [2018-03-29 12:22:02] Chip Revision ........................ 8.1 [2018-03-29 12:22:02] Multimedia Card Revision ............. 1.5 (eMMC v4.41) [2018-03-29 12:22:02] Serial Number ........................ 0x00000615 [2018-03-29 12:22:02] Memory Manufacturing Date ............ May, 2017 [2018-03-29 12:22:02] [FINISH OPERATION_ID = 26] This one I can not read at all. [2018-03-29 12:25:06] [START OPERATION_ID = 27] [2018-03-29 12:25:09] Open serial port...OK [2018-03-29 12:25:09] Connecting to the RIFF Box...OK [2018-03-29 12:25:09] Firmware Version: 1.49 (RIFFBOX1), JTAG Manager Version: 1.76 [2018-03-29 12:25:09] [2018-03-29 12:25:09] Connecting to the SD/eMMC Card...OK [2018-03-29 12:25:09] Set I/O Voltage reads as 2.79V, SD_CLK Frequency is 2.50 MHz [2018-03-29 12:25:09] [2018-03-29 12:25:09] Detected eMMC Chip, ID: 0x65/0x6F (M MOR ), User Area Partition = 0x000075700000 Bytes (1.83 GB) [2018-03-29 12:25:09] [2018-03-29 12:25:09] Reading "User Area Partition" address space from 0x000000000000 to 0x0000756FFFFF [2018-03-29 12:25:09] ERROR: Read Failed with Error Code: (17:62). Terminating at 0x000000000000 [2018-03-29 12:25:09] [FINISH OPERATION_ID = 27] Can some explain me what is wrong? |
04-11-2018, 16:18 | #2 (permalink) | |
Insane Poster Join Date: Jan 2011
Member: 1485943 Status: Offline Thanks Meter: 55 | Quote:
