06-30-2016, 11:47 | #1 (permalink) |
Insane Poster Join Date: Nov 2006 Age: 42
Member: 390178 Status: Offline Thanks Meter: 8 | samsung tab p5510 dead boot omap 4430 any solution please Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.39 (RIFFBOX1), JTAG Manager Version: 1.61 Selected Resurrector: [Samsung P5110 XLoader+ V1.0.4773.52186] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000034 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
06-30-2016, 12:00 | #2 (permalink) |
Member: 390178 Status: Offline Thanks Meter: 8 | probleme solved thnx Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.39 (RIFFBOX1), JTAG Manager Version: 1.61 Selected Resurrector: [Samsung P5110 XLoader+ V1.0.4773.52186] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0100/0x0015 (MAG2GA, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0100/0x0015 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK Resurrection complete! |
The Following User Says Thank You to ajmi_gsm For This Useful Post: |
