09-17-2013, 23:40 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Samsung W339 ERROR: Read/Write memory failed during H/W Init. I Have A Samsung W339 Cellphone, It's Good Connect With Riff But Error In Read Memory. Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [Samsung M569 V1.0.4792.61368] Connecting to the dead body...OK Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Detected dead body ID: 0x120FC0E1 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [Samsung M569 V1.0.4792.61368] Connecting to the target...OK Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x120FC0E1, IR Length = 0x04 bits Total IR length: 0x0004 bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x120FC0E1: Qualcomm MSM6125, H/W Rev. #1 When I Read Memory. Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Target: [MSM6125, 2.60V, TAP0] Connecting to the MSM6125 target...OK Detected dead body ID: 0x120FC0E1 - IGNORED! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resetting and Halting target...OK R0 = 0x60000004 R6 = 0x025C4DDC R12 = 0x00012E33 R1 = 0x00000000 R7 = 0x018C19C0 R13 = 0x02467AE0 R2 = 0x00000000 R8 = 0x00000000 R14 = 0x00012EA3 R3 = 0x00000000 R9 = 0x00000000 R15 = 0xFFFF0000 R4 = 0x0000000C R10 = 0x0246734C CPSR = 0x000000D3 R5 = 0x025C4FE8 R11 = 0x00000000 Connecting to MCU's NAND Memory Controller...FAILED ERROR: Read/Write memory failed during H/W Init. |
09-18-2013, 21:44 | #3 (permalink) | |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Offcourse I Tried With "DCC Read/Write" But It Didn't Work. Here Is Log. Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [Samsung W299 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x120FC0E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x04010000000000000000000000800000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. | |
