05-01-2013, 09:59 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Sensation XE PG58130 Z715e Boot Repair Problem!!!!!!! Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [HTC Sensation (PG5813001) V1.0.4557.3764] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4F1F0F0F, IR Length = 0x04 bits Device on TAP #1: ID = 0x104210E1, IR Length = 0x0B bits Total IR length: 0x000F bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x104210E1: Qualcomm MSM8260, H/W Rev. #1 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [HTC Sensation (PG5813000) V1.0.4557.1879] Connecting to the dead body...OK Detected dead body ID: 0x104210E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: No response from the RIFF Box. |
05-01-2013, 10:10 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Usually You need Check Wires.... Also Check GND Wire But,If Phone Dead Suddenly....This is HW Problem Plz Try This: Set Speed At 1 MHZ Connect Only USB Cable ... No Need Battrey Or Power Supply Then Press Resurrect |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
