09-08-2013, 10:07 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2020804 Status: Offline Sonork: 1646551 Thanks Meter: 0 | Sensation Z710e Resurrection complete but cant boot please help me with this one, after resurrecting the phone cant enter to fastboot or download mode LOGS: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [HTC Sensation (PG5813000) V1.0.4557.1879] Connecting to the dead body...OK Detected dead body ID: 0x104210E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 6 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (MLL00M, 0x000090000000 Bytes = 2.25 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (MLL00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body...OK Resurrection complete! salam |
09-08-2013, 22:22 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Your Phone is Normal or XE...? if It's "XE" Just Follow This: 1-Open eMMC Plugin 2-Load Working Dump File 3-Press "Load From File" 4-Select Partition 11 (Boot) and Press "Write" After Done Check Phone.... -- If Still Not Power On Try This: 1-Write "Hboot" Partition Then Check For Power On 2-Write "SBL1,2,3" Then Chek For Power On 3-Write "RMP and TZ" Then Chek For Power On if after write all needed partition still phone can't power on,You need check HW ---- Thanks |
