01-04-2013, 21:48 | #1 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1857622 Status: Offline Thanks Meter: 1 | Sensatione xl boot problem after repair Format Factory will not Dangryd and I got the phone the other phone then there was light! Now when I boot my phone will not start and Dumb burn the whole process is complete! In addition, the new handset I wanted to help in a lot of English Nmbdanm |
01-04-2013, 23:32 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I did Check Your Phone in 2days earlier...So,I Think you did try something in bad way,,, Anyway,if resurrect,dump file,repartition can't solve your problem,you need replace eMMC....This is best way for repair your phone,i still told you.... |
01-05-2013, 10:45 | #3 (permalink) |
Member: 1857622 Status: Offline Thanks Meter: 1 | Full box and complete the repair operation performs emmc, ic flash Identifies any error that these two pieces are not broken! Mr. nuri I already have problems with the phone ic flash or hard May have stumbled ... I have a problem with the software on the phone to be overcome, such as the software for the Xbox off! Maybe replace the piece easier to draw conclusions, but the phone box and the software must be turned off از راهنمایی شما سپاس گذارم |
01-05-2013, 12:13 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Replacing eMMC is not easy way,This is best way and 99% is only option....Because if phone have a fine eMMC,Phone must turn on after "Resurrect",Then Only needed Flashing by RUU...So,if phone can't turn on,usually is HW -- But I know your phone is alive before S-Off,,,But you must understand,Any electronicaly part can die without reason....or with reason,like bad S-OFF with 3.3v in SD or etc ------------- So,Just try with SW>....if not work,you need check hw |
