06-12-2018, 09:11 | #3 (permalink) |
Freak Poster Join Date: Dec 2015
Member: 2499103 Status: Offline Thanks Meter: 60 | here is box serial and problem with support . Open serial port...OK Connecting to the RIFF Box...OK Getting RIFF Box Info...OK RIFF Box S/N: xxxx RIFF Box Firmware Version: 1.50 (RIFFBOX1) This serial number is not valid for registration! Please contact your reseller and i dont know my reseller. Last edited by legija; 06-12-2018 at 09:43. |
06-12-2018, 09:46 | #4 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Please don't post Box SN in public, read instructions carefully. SN is not invalid, You just entered it wrong. Repeat registration process and copy/paste SN properly to it's field. |
06-12-2018, 10:18 | #5 (permalink) |
Member: 2499103 Status: Offline Thanks Meter: 60 | ok i try agian.and one more thing confusing with pinout.in box different pinout and phone picture differeint pinout.please a littile bit help with pinout .box pinout is .vcc.trst .tdi.tms.tck.rtck.tdo.nrst.gnd. and fhone pinout is .dat0.clk.vcc.vccq.cmd. wich point connect to wich point. thanks still same problem.i copy s/n but same problem Last edited by mimarijaz71; 06-12-2018 at 10:24. |
06-12-2018, 10:43 | #6 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | You didn't entered SN properly, probably copied space to SN field ( _ff.xxxx:xxxx.xxxx). As for pinout, don't confuse JTAG pinout with ISP pinout. If You wan't to use ISP over JTAG port in v1 box, You should have some basic knowledge of electronics to prepare connection and understand what is what. It may look confusing, but You can always use RJ45 port if You find it hard to understand JTAG port connection. |
