02-12-2013, 09:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | serious problem on gt540 Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [LG GT540 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) Flashing the dead body...OK Resurrection complete! and phone was working good just want to add arab languge then ut was killed by LGETOOL now i'm stck with a dead unite i've try with GT540_100406_MP.dll & GT540_101007_MP.dll and same |
02-12-2013, 09:29 | #2 (permalink) |
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | LGDP2_V36_UMTS_log.txt Code: [09:27:08:140] : ============================================= [09:27:08:140] : Log is started on 12.02.2013, at 09:27:08:140, executable: C:\DOWNLOAD\LGDP2_V36_UMTS.exe (ProcID: 0x00000190), compile time : Oct 7 2010 11:25:14 [09:27:08:140] : Version : [09:27:08:140] : UNKNOWN : Req(12) -> Rsp(13) [09:27:08:156] : UNKNOWN : Req(12) -> Rsp(13) [09:27:08:171] : UNKNOWN : Req(12) -> Rsp(13) [09:27:08:171] : >> DIAG_STATUS_F FAILED [09:27:08:171] : [COM45] >>Get Model Name [DIAG_VERNO_F] [09:27:08:187] : BAD CONN MODE : Req(0) -> Rsp(3) [09:27:08:203] : BAD CONN MODE : Req(0) -> Rsp(3) [09:27:08:218] : BAD CONN MODE : Req(0) -> Rsp(3) [09:27:08:234] : BAD CONN MODE : Req(0) -> Rsp(3) [09:27:08:250] : BAD CONN MODE : Req(0) -> Rsp(3) [09:27:08:265] : BAD CONN MODE : Req(0) -> Rsp(3) [09:27:08:265] : [COM45] Get Model Name in Normal Booting FAIL [09:27:08:265] : [COM45] EMERGENCY Booting Mode [09:27:08:265] : [COM45] >> Try to Get Model Name in Emergency Mode [DLOAD_VERREQ_F] [09:27:08:281] : [COM45] BS/GT540/7Dp0501#1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} [09:27:08:281] : DLOAD_VERRSP_F : GT540 [09:27:08:281] : [COM0] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 0 - GT540 [09:27:08:281] : DLL[GT540]Model NAME match. DZ file: GT540 [09:27:08:343] : Type : PARTITION TBL, size : 464 [09:27:08:343] : Type : QCSBL HEADER, size : 9524 [09:27:08:343] : Type : QCSBL, size : 57328 [09:27:08:343] : Type : OEMSBL HEADER, size : 40 [09:27:08:359] : Type : OEMSBL, size : 458744 [09:27:08:375] : Type : AMSS MODEM HEADER, size : 40 [09:27:09:843] : Type : AMSS, size : 20455424 [09:27:09:843] : Type : APPSBL HEADER, size : 40 [09:27:09:843] : Type : APPSBL, size : 77008 [09:27:09:984] : Type : ZIMAGE_RAMDISK, size : 2490048 [09:27:35:125] : Type : SYSTEM, size : 243507264 [09:27:35:140] : Type : FOTA, size : 393216 [09:27:35:140] : Type : FOTA PACKAGE, size : 0 [09:27:35:140] : [COM45] EMERGENCY Booting Mode [09:27:35:140] : [COM45] >> Try to Get Model Name in Emergency Mode [DLOAD_VERREQ_F] [09:27:35:140] : [COM45] BS/GT540/7D [09:27:35:140] : DLOAD_VERRSP_F : GT540 [09:27:35:140] : [COM0] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 0 - GT540 [09:27:35:140] : [COM45] Pre Nand Download [09:27:35:140] : [COM45] >>Set Trusted Mode [DLOAD_NAND_SEC_MODE] sec_mode = 1 (1=trusted 0=NonTrusted) [09:27:35:140] : [COM0] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - TRUSTED MODE [09:27:35:140] : [COM45] >>NandFlashInitWithFile(PARTITION TBL) [09:27:35:140] : [COM0] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - INIT PARTITION TBL [09:27:35:156] : [COM45] Check BCPL Status ... [09:27:35:156] : [COM0] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - Check BCPL [09:27:35:156] : [COM45] >> BCPL Off ... [09:27:35:156] : >> GET DLOAD COMM MODE [09:27:35:156] : [GetCommMode] Communication mode : 2 [09:27:35:156] : [COM45] _NandDownload(QCSBL HEADER) [09:27:35:156] : [COM45] >>NandFlashInitWithoutFile(QCSBL HEADER) [09:27:35:156] : [COM0] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - INIT QCSBL HEADER [09:27:35:156] : [COM45] >>NandFlashWrite QCSBL HEADER [09:27:35:156] : [COM45] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - FLASHING QCSBL HEADER [09:27:35:156] : [COM45] ProgreassiveBar Init wParam lParam(pos)=0 - Max5 [09:27:35:156] : [COM45] WRITE_TO_FLASH Pos(1) [09:27:35:156] : [COM45] WRITE_TO_FLASH Pos(2) [09:27:35:171] : [COM45] WRITE_TO_FLASH Pos(3) [09:27:35:171] : [COM45] WRITE_TO_FLASH Pos(4) [09:27:35:171] : [COM45] WRITE_TO_FLASH Pos(5) [09:27:35:187] : [COM45] >>Nand FLASH FINALIZE [DLOAD_NAND_FINALIZE_F] [09:27:35:187] : [COM45] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - FINALIZE [09:27:35:218] : [COM45] _NandDownload(QCSBL) [09:27:35:218] : [COM45] >>NandFlashInitWithoutFile(QCSBL) [09:27:35:218] : [COM45] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - INIT QCSBL [09:27:35:234] : [COM45] >>NandFlashWrite QCSBL [09:27:35:234] : [COM45] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - FLASHING QCSBL [09:27:35:234] : [COM45] ProgreassiveBar Init wParam lParam(pos)=0 - Max28 [09:27:35:234] : [COM45] WRITE_TO_FLASH Pos(1) [09:27:35:234] : [COM45] WRITE_TO_FLASH Pos(2) [09:27:35:250] : [COM45] WRITE_TO_FLASH Pos(3) [09:27:35:250] : [COM45] WRITE_TO_FLASH Pos(4) [09:27:35:250] : [COM45] WRITE_TO_FLASH Pos(5) [09:27:35:250] : [COM45] WRITE_TO_FLASH Pos(6) [09:27:35:250] : [COM45] WRITE_TO_FLASH Pos(7) [09:27:35:250] : [COM45] WRITE_TO_FLASH Pos(8) [09:27:35:671] : UNKNOWN CE_ERROR [09:27:35:687] : UNKNOWN CE_ERROR [09:27:35:703] : UNKNOWN CE_ERROR [09:27:35:703] : UNKNOWN CE_ERROR [09:27:35:718] : UNKNOWN CE_ERROR [09:27:35:734] : UNKNOWN CE_ERROR [09:27:35:734] : UNKNOWN CE_ERROR [09:27:35:750] : UNKNOWN CE_ERROR [09:27:35:765] : UNKNOWN CE_ERROR .... ... ... [09:27:45:265] : UNKNOWN CE_ERROR [09:27:45:281] : UNKNOWN CE_ERROR [09:27:45:281] : RX Timeout : 10.0 seconds [09:27:45:281] : RX TIMEOUT [09:27:45:281] : [COM45] WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - Close Port [09:27:45:281] : Close Port<< [09:27:45:281] : FAIL [09:27:45:281] : Debug Log Start ====================================== [09:27:45:281] : Flash Programming [09:27:45:281] : NandAddr : 0x00000001, Size : 16384 [09:27:45:281] : Debug Log End ======================================== [09:27:45:281] : [COM45] ERROR : NandFlashWrite(QCSBL) [09:27:45:281] : TYPE_WPARAM_UPGRADE_ERROR : 1010, wparam=66546 [09:27:45:281] : [COM45] ¸Þ½ÃÁö º¸³¿ - TYPE_WPARAM_UPGRADE_ERROR |
02-12-2013, 10:42 | #7 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | if you are getting problem in Flashing Then use Dump file for riff box and write it if you need dump file tell me here ok here is dump file : http://www.gsmcity.com.ua/files/riff/lg/gt540/ download and write it using riff box |
02-12-2013, 14:07 | #10 (permalink) |
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | Code: LGE Tool version: 1.95 OS Version: Windows XP [NT 5.1] Service Pack 3 Administrative privileges: yes Locale: France / French CPU frequency: 2200 MHz Total memory: 3071 MB Free memory: 2113 MB Free space on system disk C:\: 9.00 GB Free space on disk D:\: 191 MB Free space on disk E:\: 7.00 GB Free space on disk F:\: 647.00 GB Connecting with GT540 Connected Receiving phone info Getting phone info Model: GT540 Platform: LG Qualcomm Software Platform: Android SDRAM Size: 256 MB NAND Flash Size: 512 MB CPU: MSM7227 Connect mode: Emergency Info received Flashing DZ-firmware from C:/DOWNLOAD/DZ_GT540AT-01-V10a-234-10-MAY-13-2010.dz Com-port searching... Emergency mode Set trusted mode ... Initializing PARTITION TBL ... Initializing QCSBL HEADER ... Burning QCSBL HEADER ... Finalize ... Initializing QCSBL ... Burning QCSBL ... Timeout ... Timeout ... Timeout ... Flashing DZ-firmware success (01:20) |
