06-07-2014, 21:34 | #1 (permalink) |
Insane Poster Join Date: May 2012 Location: USA
Member: 1754897 Status: Offline Sonork: 100.1622738 Thanks Meter: 5 | SGH-I917 Read eMMC Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I917 V1.0.4466.60929] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x0C01000000000000000000003FFFFFFF Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55B3 (1024MB) Reading FLASH1 address space from 0x000000000000 to 0x00003FFFFFFF Is there another DLL that I need to use for RIFF to see the eMMC chip? I have attempting various settings, but still only able to see the 1GB NAND chip. Here is the 'Analyze JTAG Chain' information Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I917 V1.0.4466.60929] Connecting to the target...OK Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x1BA000E1, IR Length = 0x04 bits Device on TAP #1: ID = 0x202400E1, IR Length = 0x04 bits Total IR length: 0x0008 bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x202400E1: Qualcomm QCS8250, H/W Rev. #2 suggestions? Thanks in advance! j2 |
