07-10-2012, 14:03 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 775704 Status: Offline Thanks Meter: 14 | SHV-E160K dead boot help... Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung E160K V1.0.4535.7001] Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. May be different flash type? MY phone flash type is :KMKTS000VM-B604 |
07-10-2012, 15:30 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Please make following test, and post result: 1. Select HTC Sensation 4G model ! 2. On Box Service TAB, click advanced settings and disable IDCODE check 3. On DCC Read/Write TAB, select ROM2 and click "Read Memory" 4. Post log here |
07-10-2012, 17:40 | #3 (permalink) | |
Member: 775704 Status: Offline Thanks Meter: 14 | Quote:
Selected Resurrector: [HTC Sensation4G (PG5810000) V1.0.4557.1904] Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Settings Code: 0x2002000E000000000000000040000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. | |
07-10-2012, 17:42 | #4 (permalink) | |
Selected Resurrector: [HTC Sensation4G (PG5810000) V1.0.4557.1904] Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x20020000000000000000000040000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. | |
07-10-2012, 18:38 | #5 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Ok, thank You. There is clearly problem with connection, so You should carefully check all the wires, and of course try to use lower RTCK sampling rate. RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box. RIFF JTAG Box FAQ - Error: Wrong DCC Data Checksum. |
The Following User Says Thank You to legija For This Useful Post: |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
