06-14-2013, 18:25 | #1 (permalink) |
Crazy Poster Join Date: Mar 2011
Member: 1528503 Status: Offline Sonork: 100.1591188 Thanks Meter: 15 | SKY A760S error Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Pantech A760S V1.0.4694.5878] Connecting to the dead body...OK Detected dead body ID: 0x104200E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
06-15-2013, 06:56 | #2 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 468656 Status: Offline Thanks Meter: 76 | ERROR: RAM memory selftest failed. This error can be caused by numerous reasons. In most cases, it's due to bad connection (unstable NRST signal line), or RTCK/TCK sampling rate too high. User should check connection, and adjust RTCK/TCK sampling rate to lower value: This can be also target device problem. DCC loader upon startup checks target device RAM (if external RAM is used) and in case that selftest fails, it will return this error. Easiest was to diagnose this is to run generic DCC loader DLL. Generic DLL-s use internal MCU SRAM, and in case that You can boot target device without problems using generic DLL, and with model specific You have this error, it's hardware problem. Example - HTC Desire DLL returns "RAM memory selftest failed." error, while QUALCOMM QSD8xxx NAND works without errors. |
The Following User Says Thank You to duyphuong3000 For This Useful Post: |
