07-17-2013, 12:16 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Sky A800s Repair Imei not work BB have again but it lost imei then follow by supporter Pantech Sky A800s: To write this file, You can use eMMC plugin: 1. Start the plugin on "Useful Plugins" TAB 2. Click "Load layout from device" 3. Right click on "P4A" partition and select "Inject Data from file" 4. Select downloaded file "A800S_P4A_MSM_ST1_000004400000_P4A.bin" 5. Click "Flash Partition" Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Pantech A800S V1.0.4706.11688] Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 1 MHz Settings Code: 0x00010600000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (KYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (KYL00M, 0x000000080000 Bytes = 0.50 MB) Reading FLASH1 address space from 0x00000FC00000 to 0x00000FEFFFFF Completed in 00:00:59.264 (Average Transfer Rate: 51.84 kB/s) thanks |
07-19-2013, 19:30 | #4 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: china
Member: 1737647 Status: Offline Sonork: 100.1645466 Thanks Meter: 278 | Quote:
The Following User Says Thank You to MOORC For This Useful Post: |
07-20-2013, 08:45 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | @089999945 you need 512mb full dump to repair imei and basband after write dump need to update phone via IE |
07-20-2013, 12:35 | #7 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | i have but its 312 mb will let me do something for you |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
07-23-2013, 07:07 | #11 (permalink) |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | i write it with dump file 512mb & 94000000-REC-EFS-SDCARD.BIN my imei still lost,how can i fix it? pls help me all user and team. thanks |
07-23-2013, 07:09 | #12 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | the problem is that i am unable to upload it to any host server , daily i have just one hours and its take more time |
