Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 03-16-2017, 09:49   #1 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 785
Sky IM-A820L repair ok but still dead
hi dear Riffbox team,
have sky im-a820l boot repair successfully repaired but still dead. not going to download mode not switching on.
here is repair logs.
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.41 (RIFFBOX1), JTAG Manager Version: 1.65
Selected Resurrector: [Pantech A820L V1.0.4694.64556]
Connecting to the dead body...OK
Detected dead body ID: 0x105310E1 - CORRECT!
Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (KYL00M, 0x0003AB400000 Bytes = 14.68 GB)
Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (KYL00M, 0x000000080000 Bytes = 0.50 MB)
Flashing the dead body...OK
Resurrection complete!
and after successfully repaired show again qualcomm hs-usb qdloader 9008 but set not come alive
waiting for you answer
thank you
br
WBGSM
Old 03-16-2017, 10:37   #2 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
Write full dupm file and check if same then EMMC Damage
Regards
.::M Irfan::.
Old 03-16-2017, 10:51   #3 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 785
Regards
.::M Irfan::.
JazakaALLAH Khair but Sir Where will be Tested Dump file if you have link pelase provide me
WBGSM
Page generated in 0.13735 seconds with 8 queries
