12-07-2010, 11:32 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | [SOLVED] AMOI SKYPE S1 Repair/Full Flash Problem Now Set Is Not Power ON Switch to "DCC Read/Write" TAB - Select "Access ROM1 Address Space" - Check "Auto Fullflash size" - In "main" field open desired backup file - Check "Image Files use Used" - Check "Use Address as Offset for Flash Files" - Click "Write Flash" Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [..............] Connecting to the dead body...OK Detected dead body ID: 0x100D40E1 - IGNORED! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00AD/0x0036 (64MB) Writting FLASH1 memory from 0x00000000 to 0x03FFFFFF Completed in 00:10:02.047 (Average Transfer Rate: 112.26 kB/s) Br UMER |
The Following User Says Thank You to maplegsm For This Useful Post: |
12-07-2010, 12:32 | #3 (permalink) |
Freak Poster Join Date: Sep 2000 Location: Latvia, Terra, Solar System
Member: 2145 Status: Offline Thanks Meter: 36 | Certainly I'm not sure, but can guess that at write operation preparation stage sw does not check board NAND flash for bad blocks. And if so , then fullflash image readed from other board could be not completely written into yours. And if so , then at the end you may have dead board. RDGS VIK |
12-07-2010, 12:50 | #4 (permalink) | |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Quote:
12-07-2010, 19:02 | #5 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Sorry, i could not access the internet, some upgrades at my local ISP. As i can see, You've done all right, and yet it doesnt work. At first glance i could only think that this could be related to different flash chip type, since there was no bad blocks reported. So You could try to enable ECC module, it will recalculate spare data, instead of cloning it. Just to say - this full backup was tested by few users already, and there was no troubles reported. |
The Following User Says Thank You to legija For This Useful Post: |
12-13-2010, 11:12 | #8 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: india
Member: 621455 Status: Offline Sonork: key4unlock Thanks Meter: 118 | Amoi -Skype WP-S1 repair Quote:
Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [Samsung G810 Modem] Connecting to the dead body...OK Detected dead body ID: 0x100D40E1 - WRONG!!! ERROR: Current ID does not belong to the Samsung G810 Modem family can u tell me exact which model should i select ..... | |
12-13-2010, 13:46 | #10 (permalink) |
Member: 621455 Status: Offline Sonork: key4unlock Thanks Meter: 118 | after that stuck in proccess ....... Detected dead body ID: 0x100D40E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00AD/0x0036 (64MB) Writting FLASH1 memory from 0x00000000 to 0x03FFFFFF ERROR: Stopped due to multiple communication errors. Terminating at 0x00480000 |
SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems | GsmMunna | HWK | 1801 | 05-18-2023 13:08 |
Problem reseting x2 with my key what to do? (ANSWERED) | wisdom001 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 12-07-2010 22:17 |
unlock problem with 5800d-1 (ANSWERED) | my_foo | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 12-07-2010 22:11 |
who succeed repair rm-470 6700c-1? trick pls (ANSWERED) | MGT SOFTWARE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-07-2010 16:43 |
