03-16-2012, 09:12 | #18 (permalink) |
Junior Member Join Date: Dec 2006
Member: 404023 Status: Offline Thanks Meter: 0 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.31, JTAG Manager Version: 1.41 Selected Resurrector: [HTC EVO3D (PG86300) V1.0.4456.5060] Connecting to the dead body...OK Detected dead body ID: 0x104210E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x004A (HYNIX, 0x000090000000 Bytes = 2.25 GB) Flashing the dead body...OK Resurrection complete! phone still died any idea? |
03-16-2012, 22:36 | #21 (permalink) |
Member: 404023 Status: Offline Thanks Meter: 0 | problem with htc evo 3d Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.31, JTAG Manager Version: 1.41 Selected Resurrector: [HTC EVO3D (PG86300) V1.0.4456.5060] Connecting to the dead body...OK Detected dead body ID: 0x104210E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x004A (HYNIX, 0x000090000000 Bytes = 2.25 GB) Flashing the dead body...OK Resurrection complete! phone still died any idea? |
03-17-2012, 00:09 | #24 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | check last bug fix updates redownload DLL and repair it again . |
03-25-2012, 22:03 | #25 (permalink) |
Registered User Join Date: May 2005 Location: My Office
Member: 143939 Status: Offline Thanks Meter: 264 | [Solved] HTC evo 3D - camera problem Hi - Riff team HTC evo 3D after downgrade HBoot to 1.49.0018 camer not working any solution to solve camea problem or to upgrade HBoot. |
The Following User Says Thank You to KHJAMAL For This Useful Post: |
03-25-2012, 23:15 | #26 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | it's easy and it's your own risk go to HTCdev - Unlock Bootloader and SignUp and login then select your model and follow instruction ... no need unlock boot-loader .....just follow for see download hboot-XXXXX.exe page........and download RUU-h.boot.exe same by your firmware..........then install it.. enjoy |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
