Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 04-20-2012, 08:23   #76 (permalink)
Member: 383241
Thanks Meter: 2
Camera Not working after JTAG 2 time 1st with Sharp and 2nd with Liteon, Kindly help me and provide me Camera Drivers...
HTC Evo 3D X515m
Model: PG86300
Part #: 99HNJ041-00
Serial #: HT18BV206081
MBSN Number On Green Sticker: 4176115 207089B
Old 04-20-2012, 09:40   #77 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,266
HTC Evo 3D X515m
Model: PG86300
Part #: 99HNJ041-00
Hi,
Try this WLAN partition, and report results.
Use method described by aresares.
The Following 2 Users Say Thank You to legija For This Useful Post:
Old 04-20-2012, 21:55   #78 (permalink)
el-safwa's Avatar
Member: 158471
Sonork: 100.1588029
Thanks Meter: 104
Yesterday i make this the solution and work 100% Thanks BABAK NURI for help me
Old 04-21-2012, 08:34   #79 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
Originally Posted by legija View Post
Hi,
thanks .............. camera problem solved
Old 04-24-2012, 12:01   #80 (permalink)
Member: 85753
Sonork: 106061
Thanks Meter: 33
Thumbs up Thank you master
Originally Posted by aresares View Post
I was repaired htc evo 3d camera problem and thanks legija he help to me he is the best supporter
now how to repair htc evo3d camera problem after riif
first step you must check your camera model because evo3d have 3 different model here is the pdf check your camera model
DOC-00107091 [Shooter_U] Main board and 3D camera compatibility notice A03.rar download - 2shared
after you must found a working phone for copy camera driver but camera model is must be same
now connect working phone riffbox go to useful plugins
select emmc partition table and active plugin
click load file from device and select list of partition 5 it name is P73_WLAN
right click partition and save into file this is your backup
now connect your defective phone to riffbox go to emmc partition and active plugin load image from device select part 5 and right click inject from file select your backup click flash partition
it is tested by me workinkg %100 I was repaired my phone with this method sorry my bad speak eng.. if you need help contac me on msn [email protected]
I will uplad here my backup this camera driver is for sharp 99HNJXXX-04 MY camera id is 41769136042841 on greensticker
P73_WLAN.rar download - 2shared
This solution %10000000 workking sharp cameraa
Thank you master
RESPECTS
Old 04-24-2012, 17:58   #81 (permalink)
Sethxp's Avatar
Member: 9291
Thanks Meter: 84
All who sucesfully repair camera please test gps functionality, i have 2 phones without working gps after ressurection and camera repair.
I will make new thread if this new error confirms.
Regards
Seth.cz
Old 04-30-2012, 23:08   #82 (permalink)
Member: 333519
Sonork: 100.1620327
Thanks Meter: 16
[Solved]htc evo 3d error repairing
please i have htc evo 3d when i try to repair it i have this error: the phone is perfect only i need repair imei, im ssure that the conections are ok
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (KLL00M, 0x000090000000 Bytes = 2.25 GB)
Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (KLL00M, 0x000000080000 Bytes = 0.50 MB)
ERROR: Failed to unpack received data. Terminating.
Flashing the dead body...OK
Resurrection complete!
Old 04-30-2012, 23:24   #83 (permalink)
Member: 333519
Sonork: 100.1620327
Thanks Meter: 16
problem solved
problem solved just untick generic resurrection
Old 05-01-2012, 14:37   #84 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,157
thanks MR: aresares
1000000000000000% work
Old 05-01-2012, 18:18   #85 (permalink)
Sethxp's Avatar
Member: 9291
Thanks Meter: 84
And what about gps? Also works ? Test it please.
Old 05-02-2012, 10:17   #86 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,157
Old 05-02-2012, 10:18   #87 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,157
make reflash ................
Old 05-02-2012, 11:05   #88 (permalink)
Sethxp's Avatar
Member: 9291
Thanks Meter: 84
nice answer
phone is reflashed already after repair, i can switch on gps in menu [like yours] but gps not getting single satelite
and yes, gps was working before ressurection and camera repair...
Old 05-04-2012, 23:43   #89 (permalink)
Karlos007's Avatar
Member: 170013
Thanks Meter: 42
nice answer
Ok, I have spent some time to investigate and found out, that gps calibration data are stored in mmcblk0p3. So I downloaded the file from working phone and uploaded it to corrupted phone and gps is working.
1. Root your phone
2. Copy mmcblk0p3.img to you sdcard
2. Run adb
3. Type adb shell
4. Type su
5. Type dd if=/mnt/sdcard/mmcblk0p3.img of=/dev/block/mmcblk0p3
6. Type reboot
You can download file here
B.R.
Karel
The Following 3 Users Say Thank You to Karlos007 For This Useful Post:
Old 05-05-2012, 12:41   #90 (permalink)
Sethxp's Avatar
Member: 9291
Thanks Meter: 84
Still zero satelites
Seth
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 18:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.44872 seconds with 9 queries
