07-20-2011, 12:22 | #1 (permalink) |
Insane Poster Join Date: Mar 2005 Location: ECOWAS
Member: 125844 Status: Offline Sonork: 100.1589441 Thanks Meter: 8 | [SOLVED with QSC1100 DLL] any solution for new s100 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.22, JTAG Manager Version: 1.29 Selected Resurrector: [ZTE S100] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - WRONG!!! ERROR: Current ID does not belong to the ZTE S100 family. step 2 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.22, JTAG Manager Version: 1.29 Selected Resurrector: [ZTE S100] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. any solution for this zte s100 new security |
07-20-2011, 14:37 | #3 (permalink) |
No Life Poster Join Date: May 2011 Location: india
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. Hardwere Problem Or Need Battery Power During DCC Write |
07-21-2011, 14:39 | #4 (permalink) |
Member: 125844 Status: Offline Sonork: 100.1589441 Thanks Meter: 8 | Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. Hardwere Problem Or Need Battery Power During DCC Write i try hardware not hardware problem any solution pls |
07-21-2011, 14:47 | #5 (permalink) |
Member: 125844 Status: Offline Sonork: 100.1589441 Thanks Meter: 8 | Contact me on messenger id solve your problem CDMA MOBILE AREANA alwarmobile pls i dont see you online give me your phone number then i will call you or drop mesage fr me on my sonork |
07-22-2011, 14:27 | #6 (permalink) |
Member: 125844 Status: Offline Sonork: 100.1589441 Thanks Meter: 8 | zte s100 new security not supportd by riff Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. i need assistant from someone pls veryurgent |
07-23-2011, 09:32 | #7 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: DELHI,INDIA
Member: 427627 Status: Offline Thanks Meter: 160 | Quote:
Plz Change Sampling Rate Betweeen 1mhz And 4mhz And Try Again Wbr lalitg | |
07-23-2011, 10:30 | #8 (permalink) | |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
Please check exactly which CPU is in this PCB version. Then use generic DLL to try reading flash. Generic DLL-s don't use phone SRAM, but internal CPU RAM, hence it will not depend on hardware configuration on specific phone. And of course UPDATE box firmware and JTAG Manager exe to latest versions first. | |
The Following 2 Users Say Thank You to legija For This Useful Post: |
07-23-2011, 16:08 | #9 (permalink) |
Member: 125844 Status: Offline Sonork: 100.1589441 Thanks Meter: 8 | Hi, Please check exactly which CPU is in this PCB version. Then use generic DLL to try reading flash. Generic DLL-s don't use phone SRAM, but internal CPU RAM, hence it will not depend on hardware configuration on specific phone. And of course UPDATE box firmware and JTAG Manager exe to latest versions first. i will try it now and post result |
07-28-2011, 16:16 | #12 (permalink) |
Member: 125844 Status: Offline Sonork: 100.1589441 Thanks Meter: 8 | ////////////////////////////////////////////// Last edited by legija; 07-28-2011 at 16:26. Reason: Warnign ! Next off topic and i will close this thread. |
07-29-2011, 13:17 | #13 (permalink) |
Member: 427627 Status: Offline Thanks Meter: 160 | Hi, Here Is Setting For Zte S100 Famliy, If User Have Remains Problem,Then Plz Contact Me On Sonork Or Yahoo Thx lalitg Last edited by lalitgvarshney; 07-29-2011 at 13:28. |
07-29-2011, 13:19 | #14 (permalink) |
Member: 125844 Status: Offline Sonork: 100.1589441 Thanks Meter: 8 | HERE IS THE CPU INFO QUALCOMM QSC1100 B00162.0 E2034006 PlatformID: 0x122CE0E1 (QSC11x0) SW version: VISAFONE_S100_RNTL01FV1.0.0B02 Last edited by legija; 07-29-2011 at 14:20. Reason: Off topic removed |
07-29-2011, 13:32 | #15 (permalink) |
Member: 427627 Status: Offline Thanks Meter: 160 | Hi Its A new Version Zte S100 With qsc 11xx Famliy Cpu, Plz Use QSC1100 X14 Nor Dll For Reading And Write Process...... If U Getting Any Problem Then U r Welcome To Join Me ,Will help u Solve Ur Problem Wbr lalitg Last edited by legija; 07-29-2011 at 14:20. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
