08-12-2010, 18:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2004
Member: 61389 Status: Offline Thanks Meter: 193 | [SOLVED - RIBBON CABLE PROBLEM] topaz problem i have problem..again... like the herald. Tomorrow or the next week i try to change my riff, or if you have any idea pls share details: - i follow step-by step the user manual - same usb port (and cable) - same mini usb - same cca 7 cm direct soldered cable (ort and riff use same pinout) - only the box changed no restart no additional thing - ORT read flash succesfull ( or any operation, the phone live again) ORT: Riff: |
08-13-2010, 11:35 | #5 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Most probably You wrongly connected the NRST signal. Contact me on ICQ, we need to investigate this. ICQ#: 299-912-089 |
The Following User Says Thank You to legija For This Useful Post: |
08-13-2010, 17:08 | #8 (permalink) |
Member: 61389 Status: Offline Thanks Meter: 193 | thx for the great support. Problem solved if possible pls check all user the original grey cable, when twisted maybe lost the connect. Now i have 4 set and thre cable set facotry damaged only 1 working fine. regards j. |
08-16-2010, 10:28 | #9 (permalink) |
Member: 61389 Status: Offline Thanks Meter: 193 | hello some new info about topaz After the resurrection: Case 1: if your phone powered on you are lucky (don't forget the hard reset.. ) Case 2: your phone powered on but only the bootloader (tricolor screen) on the display (reflash any rom and enjoy) Case 3: Trying to reflash but always interrupt the RUU (262 flash write error) - Try to download other RUU image - Try to flash via sd card - Try to OliNex hard spl still having promblem? download this image: RapidShare: 1-CLICK Web hosting - Easy Filehosting you need sd card formatted to FAT32 put the image to root rename to TOPAIMG.nbh power on the phone if ask press power button flashing and succesfull (this rom not contain bootloader :P after flash you can check (vol down+power on) still the riff bootloader on he screen ) regards j. |
The Following 8 Users Say Thank You to jodge For This Useful Post: |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
