01-24-2011, 14:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | [SOLVED] TG01-can't repair! Code: pen serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.22 Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 What's the problem? Thanks! |
01-25-2011, 11:16 | #3 (permalink) |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | When I select hd2 instead of tg01 all functions is working fine. Here is fullflash read from tg01 conected like hd2. Other operations for tg01 works but resurrct method and fullflash read/write don't work; Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.22 Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Model selected: TOSHIBA - Toshiba TG01 Detected dead body ID: 0x202400E1 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.22 Selected Resurrector: [Toshiba TG01] Connecting to the target...OK Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x202400E1, IR Length = 0x04 bits Total IR length: 0x0004 bits Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.22 Selected Resurrector: [Toshiba TG01] Getting EmbeddedICE-RT registers...OK 00 = 0x00000010 08 = 0x00000000 10 = 0x00000000 01 = 0x00000000 09 = 0x00000000 11 = 0x00000000 02 = 0x00000000 0A = 0x00000000 12 = 0x00000000 03 = 0x00000000 0B = 0x00000000 13 = 0x00000000 04 = 0x60000000 0C = 0x00000000 14 = 0x00000000 05 = 0x00000000 0D = 0x000000F7 15 = 0x000000F7 06 = 0x60000000 0E = 0x00000000 16 = 0x00000000 07 = 0x00000000 0F = 0x00000000 17 = 0x00000000 Thanks! |
01-25-2011, 11:46 | #4 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Ok, let me take look into damaged full flash, will give You instructions today how to fix it. |
The Following User Says Thank You to legija For This Useful Post: |
01-25-2011, 12:02 | #5 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Ok, as i can see this phone is erased by ORT. Download full backup from this link : http://rapidshare.com/files/42229365...ull_backup.rar Connect phone to RIFF, go to DCC TAB, select HTC HD2. Open full backup, and set following options : - Start address : 0x00000000 - Data Length: 0x00800000 - Check "Image file is used" - Check "Use address as offset" - Select ROM1 Other options must be NOT Checked, click "Write". This will restore erased area in modem part. After this perform ROM upgrade using TG01 downloader. |
01-25-2011, 13:02 | #6 (permalink) |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | It worked like charm Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.22 Selected Resurrector: [HTC HD2 (Leo)] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x0098/0xD5BC (512MB) Writting FLASH1 memory from 0x00000000 to 0x007FFFFF Completed in 00:01:13.328 (Average Transfer Rate: 115.21 kB/s) Regards! |
The Following User Says Thank You to Burebista For This Useful Post: |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
Contact Service Repairer 1.2 by Bartek | Allen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-23-2011 09:00 |
Can't get Network on my 5110 | VK | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-18-2001 00:19 |
New!! Nokia Flash Checksum And Contact Service Repair | HookerGsM | Main Sales Section | 0 | 01-02-2001 10:12 |
Phone can't find 1-2-1 | robin.munro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-01-2000 18:04 |
