10-02-2010, 14:49 | #16 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Also - You may need to disconnect all flex cable connectors from PCB. If box and ribbon cables are okay, it must work, even at maximum speed ! |
10-02-2010, 16:37 | #18 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | There is not much options - if You are sure that cables and soldering is done properly, and still have connection problems, then only reasonable solution is to replace box. |
11-10-2010, 17:43 | #19 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Vojvodina Age: 45
Member: 44395 Status: Offline Thanks Meter: 7 | ERROR: Wrong response code from the RIFF Box: 0x45 I want to make a full backup but i'v got this error, could someboudy help me out! THX! Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 |
05-11-2011, 16:57 | #20 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Now on earth Age: 48
Member: 75290 Status: Offline Thanks Meter: 56 | repair GT01 Quote:
JUST upload new firmware with FULL battery - I used from NOkia 6300 BR ERSA Seb | |
06-09-2011, 16:15 | #21 (permalink) |
No Life Poster Join Date: Jan 2003 Location: ALGERIEN
Member: 19423 Status: Offline Sonork: 69566 Thanks Meter: 246 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.24, JTAG Manager Version: 1.32 Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 |
06-09-2011, 17:17 | #22 (permalink) | |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
You have different HW version there, and You need to use HTC HD2 DLL to write files manually. If You need to unlock it, just write EFS file from here : http://jtagbox.com/downloads/tg01/Unlocked_EFS.rar If You need to repair phone, use full dump. | |
06-09-2011, 17:51 | #23 (permalink) | |
Member: 19423 Status: Offline Sonork: 69566 Thanks Meter: 246 | Quote:
06-09-2011, 19:26 | #24 (permalink) |
Member: 19423 Status: Offline Sonork: 69566 Thanks Meter: 246 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.24, JTAG Manager Version: 1.32 Selected Resurrector: [HTC HD2 (Leo)] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) Writting FLASH1 memory from 0x01640000 to 0x01E5FFFF Completed in 00:00:43.360 (Average Transfer Rate: 197.88 kB/s) unlock DONE Thanks ************************************************** ************* NEXT UPDATE ADD HINT ABOUT TOSHIBA TG01 NEWS HARDWARE UNLOCK METHOD 2 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
