12-08-2013, 10:53 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | ST23 xpiria miro boot repair. some time set have hardware issue. but befor do H/W need conform it h/w or boot dammdge. riff officially not support this phone but i think it can do unofficially. any one khow how to do it pls repply. do not post nonsense answer. |
01-20-2014, 21:51 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi If you want check phone for HW fault or Boot Problem,You Need Ask From Your Client if phone have a suddenly dead,it's HW problem if phone dead after flash wrong firmware or damage during unlock boot-loader,install CWM,Rootng phone or other sw method,,,This is boot problem Anyway,We have pinout and boot file Please contact me via ICQ if you want pinout and boot partitions Thanks |
01-25-2014, 06:42 | #5 (permalink) | |
Member: 1133072 Status: Offline Thanks Meter: 505 | Quote:
thank br, phone have hv faulty. already fix it, | |
03-07-2014, 22:16 | #9 (permalink) |
Insane Poster Join Date: Oct 2005
Member: 188132 Status: Offline Thanks Meter: 2 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [SE ST23i V1.0.5179.40029] Connecting to the dead body...OK Detected dead body ID: 0x106030E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
03-10-2014, 12:53 | #10 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | [ LT23i ] boot repair problem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [SE ST23i V1.0.5179.40029] Connecting to the dead body...OK Detected dead body ID: 0x106030E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
03-11-2014, 14:06 | #13 (permalink) |
Freak Poster Join Date: Aug 2006 Location: in ***'s hand
Member: 326924 Status: Offline Thanks Meter: 31 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [SE ST23i V1.0.5179.40029] Connecting to the dead body...OK Detected dead body ID: 0x106030E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
03-11-2014, 16:33 | #14 (permalink) | |
Insane Poster Join Date: May 2005 Age: 45
Member: 148314 Status: Offline Thanks Meter: 1 | st23i Quote:
problemm ..is same............pls????.................. | |
03-11-2014, 21:38 | #15 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2129911 Status: Offline Thanks Meter: 0 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [SE ST23i V1.0.5179.40029] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x106030E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
