05-31-2015, 00:59 | #1 (permalink) |
Registered User Join Date: Jul 2012
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | Unable to Write Backup Using HDDRaw and Riff Box (but only erase) I have phone in hand it suddenly dead after i put microsd with TF update inside but it never do update because it's say, " Only newer version allowed to upgrade..." after that message appear i took the battery. But when i trying to re-attach the battery and turn it on again, it's dead. Phone detected as 9006, write using HDDRaw, it's error 21 at 0x0000000 address (so i think it can't be written from the beginning address) The i try to write full dump using Riff Box, same problem happen. I cant write the dump it's say, error 0x21 at 0x0000000. Erase GP1 and Area UserData not help, writing only boot give the same error. I can erase but can't write. this is emmc problem or other hardware problem maybe emmc not supplied enough power or what? Thanks |
06-01-2015, 20:48 | #2 (permalink) |
Insane Poster Join Date: Aug 2013 Location: west java indonesia Age: 41
Member: 2009275 Status: Offline Sonork: 100.1646190 Thanks Meter: 24 | It's simple, on user area try read 1mb data and save, write/erase 1mb data . After write/erase read again and save with another file name. Compare to data with hex editor or notepad ++. If u see same data. It's have emmc error with lock data. Many normal phone after hard reset, nothing change because bad emmc. If u have emmc tool box. Try format emmc. If after format usb detected as 9008. Emmc work fine. |
