11-12-2012, 18:14 | #197 (permalink) | |
Freak Poster Join Date: Jan 2005 Location: miami Age: 47
Member: 112190 Status: Offline Thanks Meter: 21 | Quote:
same jig for the I9100 will work?? in the instruction says 11 pin jig??? so any clue or even better schematic for this jig thanks best regards linterna1 | |
11-15-2012, 10:18 | #199 (permalink) |
Freak Poster Join Date: Aug 2004 Location: romania Age: 44
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | i9300 jig?? the jig for unbricking i9300 is the normal 301k jig or do we need special Anyway JIG ???? if someone get fixed one bricked i9300 with normal 301k jig, please tell us the exact procedure, how do you supplied power to the board, via usb connector using pin 11 or via battery connector?? |
11-19-2012, 03:57 | #202 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 197485 Status: Offline Thanks Meter: 19 | I repair my phone with this guide but I can not find firmware that contain pda , pit ,csc and phone files could any one give me this flash file my phone go to download mode and odin find it thanks |
11-19-2012, 23:23 | #203 (permalink) |
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | question How did you do it? Please post here details of the procedure you aplied! Please help other people that are facing this problem with an advice or a helping guide how to do it correctly. Please tell us if you used normal, 301k, jig or something else and how did you supplied power to the board? Thank you in advance!!!!! |
11-22-2012, 10:54 | #204 (permalink) |
Freak Poster Join Date: Sep 2009 Location: Iasi , Romania Age: 40
Member: 1119968 Status: Offline Thanks Meter: 10 | i9250 strange problem bootloader the phone was dead, recover'it with omap-flash , but whet i try to flash bootloader it gives error " failed (status read failed <too many links> " image get's fuzzy and it freeze. i have to repair again with omap flash may be hardware ? the image get's fuzzy like it's double |
11-24-2012, 22:06 | #205 (permalink) |
Crazy Poster Join Date: Oct 2009
Member: 1145114 Status: Offline Thanks Meter: 5 | i have repaired today 1p i9250 , all goes well but i cant enter in download mode but when put set in download mode i get a phone & pc image at display and in this condition odin detect the set as in downloading mode , so here start my issue when i pres flash odin just hang in 1st stage and flashing never starts , i tryied to flash with others tools also but no way to get started flashing . any guy got this issue and solved it ? if yes plz share thx Last edited by BABAK NURI; 11-25-2012 at 05:43. Reason: No need log |
11-25-2012, 05:45 | #206 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
It's mean phone stuck in "Debug Screen"....So,You Need USB+jig for force start downloading or Just select any CF-Root in "PDA",Then Press "START" Then,You have "Downloading" | |
11-25-2012, 05:48 | #207 (permalink) | |
I Think not HW Because Omap-F Can't Repair Done if eMMC Have a Problem...But Possible -- Anyway,You Need Use Original Google Image,And SGN-Toolkit(search Google) for Flashing | |
11-25-2012, 05:50 | #208 (permalink) | |
normal jig can't work for I9300...Actually you need USB+JIG,Then "Power Key" -- I Mean,Connect jig to phone,connect usb to pc.Put battrey and press and keep power on key for 6sec.. | |
11-27-2012, 17:00 | #209 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1845194 Status: Offline Thanks Meter: 0 | hi i have a gnexus gsm and i have got this error some help ? C:\Users\marco_000\Desktop\OMAPFlash>GOTO __loop » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t at line : 1 » -omap 4 » -t 36000 » -p OMAP4460_TUNA_8G_HS_PRO » -2 » chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO » chip_download EMMC Targets\Projects\tuna\sbl.img » command cold_sw_reset » Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t » @Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » Looking for device (omap usb) » Please turn off device » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id » AsicId items 05 » AsicId id 01 05 01 44 40 07 01 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 A9 3B 84 EB 6C 83 8E 05 2A C9 FC 92 D1 6E 43 83 79 80 90 25 » AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2 25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC » AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC » Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS » Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si gned.2nd.hs_pro » Entering parameter filemapflash2nd.txt at line: 46 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4460 _tuna_8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4460_tuna _8g.txt » Leaving parameter filemapflash2nd.txt » Sending size of second file (0x000071B0 bytes) » Transferring second file to target (0x71B0 bytes) » Closing boot connection » Found device (omap usb) » Waiting for 2nd » Unknown status message 'GKAY2 2nd started?' during peripheral boot (waiting fo r 2nd) Premere un tasto per continuare . . . C:\Users\marco_000\Desktop\OMAPFlash>GOTO __loop » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t at line : 1 » -omap 4 » -t 36000 » -p OMAP4460_TUNA_8G_HS_PRO » -2 » chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO » chip_download EMMC Targets\Projects\tuna\sbl.img » command cold_sw_reset » Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t » @Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » Looking for device (omap usb) » Please turn off device » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id » AsicId items 05 » AsicId id 01 05 01 44 40 07 01 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 A9 3B 84 EB 6C 83 8E 05 2A C9 FC 92 D1 6E 43 83 79 80 90 25 » AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2 25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC » AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC » Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS » Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si gned.2nd.hs_pro » Entering parameter filemapflash2nd.txt at line: 46 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4460 _tuna_8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4460_tuna _8g.txt » Leaving parameter filemapflash2nd.txt » Sending size of second file (0x000071B0 bytes) » Transferring second file to target (0x71B0 bytes) » Closing boot connection » Found device (omap usb) » Waiting for 2nd » Unknown status message 'GKAY2 2nd started?' during peripheral boot (waiting fo r 2nd) Premere un tasto per continuare . . . |
11-28-2012, 08:04 | #210 (permalink) | |
but still not working with a normal jig!!! I already tryed a lot!!! of combinations and nothing!!! not even close!!! regards linterna ps: I love disney land. | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
I am looking for information about GSM-CABLES.NE | DUPOND | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 08-03-1999 15:29 |
Selling original Nokia DAU9P cable | TheDon | Main Sales Section | 0 | 07-21-1999 15:44 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
