Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 05-19-2012, 14:25   #31 (permalink)
Member: 4600
Thanks Meter: 62
Any idea ? how to repair imei , baseband .
br.
Old 05-20-2012, 04:58   #32 (permalink)
Member: 775704
Thanks Meter: 13
what a great work ****anks
Old 05-23-2012, 17:32   #33 (permalink)
Member: 1501506
Thanks Meter: 47
I can't install the driver as the device re-enumerates via USB every 2 seconds and won't stay online long enough to install the driver. Is there a way to have the device hold in OMAP4440 mode?
Thanks!
Old 05-29-2012, 13:19   #34 (permalink)
Member: 1234013
Thanks Meter: 3
hi there i had a same problem but i fixed it with this.i just opened the omap flash thing and then connect the phone,it was doing the same thing what your phone doing.go to the device manager and select update driver when you see the omap driver for galaxy nexus and give the correct driver from the software folder,by the time its instaling driver,omap software will finish the job and you phone will turn on..
Old 06-01-2012, 23:41   #35 (permalink)
Member: 448809
gracias amigo mu bueno lo tuyo
Old 06-02-2012, 14:25   #36 (permalink)
Member: 268860
really greattttttttttt vvery very thanks
Old 06-04-2012, 16:42   #37 (permalink)
Member: 1752435
Originally Posted by pitka View Post
First you need to remove battery and then load driver for OMAP (4460usb), then its working. Looks like TI recovery procedure.
But unfortunatelly it recovered bootloader (sbl) only, in my case eMMC pda image partition still damaged and eMMC need to be formatted completely.
Would it be possible to support this eMMC by JTAG too ?
Thanks
I think I have the same issue..and this might be related to emmc bug..did you get anywhere trying to format the emmc using omap flash script or anything of the sort..thanx for your assistance
Old 06-05-2012, 20:52   #38 (permalink)
Crazy Poster
Member: 1767206
Originally Posted by legija View Post
https://rapidshare.com/files/1168981...Flash_tuna.zip
Just execute *.bat file from this package.
Installing drivers first would be pretty smart idea too.
Enjoy !
Please explain how do I install the drivers.
Old 06-06-2012, 00:01   #39 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 333
I m having problem here
after this software asking same thing all time
http://img716.imageshack.us/img716/4923/i9520.jpg
Old 06-07-2012, 02:00   #40 (permalink)
Member: 547228
thancks , please explain how to install the driver , I can't install the driver as the device re-enumerates via USB every 2 seconds and won't stay online long enough to install the driver,
Old 06-07-2012, 07:26   #41 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 333
i m stil waiting for answer can some one tell me what to do? i have dead i9520 i can connect but always give error saying
EMMC eMMC DRIVER DEINIT COMPLETE
Download failed (final data response error): Remote: : Driver init error 0x00F
F8080 - MMC CONFIG FAILURE
Elapsed time: 0:05.453 (8730 bytes/s)
Operation FAILED (Remote: : Driver init error 0x00FF8080 - MMC CONFIG FAILURE)
Elapsed time: 0:18.531
Press any key to continue . . .
Old 06-07-2012, 17:27   #42 (permalink)
communication_expert's Avatar
Member: 50511
Sonork: 100.109684
Thanks Meter: 301
i love this post use full post
Old 06-07-2012, 19:19   #43 (permalink)
Member: 1752435
OMAP lash with details output
OMAPFlash v4.15 (Aug 12 2011)
-v
Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t at line
: 1
-omap 4
-t 36000
-p OMAP4460_TUNA_8G_HS_PRO
-2
-rxtx_trace
chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO
chip_download EMMC Targets\Projects\tuna\sbl.img
command cold_sw_reset
Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t
@Targets\Projects\tuna\omap4460_tuna_hs_pro.txt
Looking for device (omap usb)
Please turn on device
Waiting for device (omap usb)
Found device (omap usb)
Requesting ASIC id
00130-000-TX 4 raw bytes: 03 00 03 F0 '????'
AsicId items 05
AsicId id 01 05 01 44 40 07 01
AsicId secure_mode 13 02 01 00
AsicId public_id 12 15 01 97 1E D2 40 84 FC E8 16 AA 20 26 62 0C 90 E0
83 26 88 80 7B
AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2
25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC
AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC
00130-001-TX 4 raw bytes: 02 00 03 F0 '????'
Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS
Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si
gned.2nd.hs_pro
Entering parameter filemapflash2nd.txt at line: 46
-pheriphalboot_reopen
Reading board configuration file Targets\Configurations\configuration_omap4460
_tuna_8g.txt
Reading definition file .\targets\definitions\definitions_omap4.txt
-board_config Targets\Configurations\configuration_omap4460_tuna _8g.txt
Leaving parameter filemapflash2nd.txt
Sending size of second file (0x000071B0 bytes)
00130-002-TX 4 raw bytes: B0 71 00 00 '?q??'
Transferring second file to target (0x71B0 bytes)
00130-003-TX 29104 raw bytes: B0 1C 00 00 00 4D 00 00 00 00 00 00 00 00 00 00
'?????M??????????' ...
Closing boot connection
Waiting for 2nd
00463-004-TX ACK
00571-005-RX: 4 raw bytes: 70 EC 8F 00 'p???'
Unknown status message 'p???' during peripheral boot (waiting for 2nd)
Old 06-09-2012, 10:32   #44 (permalink)
Member: 1769757
Hello,
I think i might have bricked my phone too. Following are my phone details.
Galaxy Nexus Verizon (CDMA)
SCH-I515
When i plug-in USB i can see OMAP4440 for a brief moment and disappears.
I ran the omap4460_tuna_hs_pro.bat. Script fails with following error.
Waiting for 2nd
Found 2nd
Looking for a driver for 'EMMC'
chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 0 width 4 delay 9 rpapi_base 0x00030400
Downloading driver
Operation FAILED (Remote: : Unknown command dri)
Elapsed time: 0:35.215
Please advise on how I can fix this.
Thanks in advance.
Old 06-09-2012, 14:50   #45 (permalink)
Member: 1752435
Originally Posted by AndroUser View Post
Hello,
SCH-I515
Waiting for 2nd
Found 2nd
Downloading driver
Thanks in advance.
- Disconnect phone and remove battery
- Open the device manager:
- Connect the usb to the pc with the mini connected to the phone.
-You have few seconds to see the omap4440 and double click, if you could not open it the first time disconnect and reconnect the usb and try again.
- Once opened update driver and select to browse the folder included in the package to install driver.
- Run the tool again..
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
I am looking for information about GSM-CABLES.NE DUPOND Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 08-03-1999 15:29
Selling original Nokia DAU9P cable TheDon Main Sales Section 0 07-21-1999 15:44
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.41897 seconds with 9 queries
