Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 06-09-2012, 18:25   #46 (permalink)
Member: 1769757
Thanks itsalllgood, for your response .
I've installed the drivers in folder 'usb_drv_windows' provided in the zip. It shows up as 'OMAP4460 USB device' in my device manager.
I re-ran the script while it was loading the device, the script runs into the same error
' Operation FAILED (Remote: : Unknown command dri)'
Question, shouldn't device be listed as OMAP4440? Do I have the wrong drivers?
Please me know if I need to provide any more device details.
Appreciate your help.
Old 06-10-2012, 15:17   #47 (permalink)
Member: 1752435
Extract the zip file before you install the driver
Old 06-10-2012, 15:57   #48 (permalink)
Member: 1769757
Hi itsalllgood,
Files were unzipped locally and driver was installed from unzipped folder. The bat/script was run from within the script folder. Following is the complete output of the script. I tried the script several times by disconnecting and re-connecting the usb cable. It always lead to the same error. Please note my battery is not connected all this while.
OMAPFlash v4.15 (Aug 12 2011)
-v
Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t at line: 1
-omap 4
-t 36000
-p OMAP4460_TUNA_8G_HS_PRO
-2
chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO
chip_download EMMC Targets\Projects\tuna\sbl.img
command cold_sw_reset
Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t
@Targets\Projects\tuna\omap4460_tuna_hs_pro.txt
Looking for device (omap usb)
Please turn on device
Waiting for device (omap usb)
Found device (omap usb)
Requesting ASIC id
AsicId items 05
AsicId id 01 05 01 44 40 07 01
AsicId secure_mode 13 02 01 00
AsicId public_id 12 15 01 31 87 C8 98 34 72 F2 3E BF 8A 12 74 37 BB 2C
43 EE 14 CD 03
AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2
25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC
AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC
Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS
Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.signed.2nd.hs_pro
Entering parameter filemapflash2nd.txt at line: 46
-pheriphalboot_reopen
Reading board configuration file Targets\Configurations\configuration_omap4460_tuna _8g.txt
Reading definition file .\targets\definitions\definitions_omap4.txt
-board_config Targets\Configurations\configuration_omap4460_tuna _8g.txt
Leaving parameter filemapflash2nd.txt
Sending size of second file (0x000071B0 bytes)
Transferring second file to target (0x71B0 bytes)
Closing boot connection
Waiting for 2nd
Found 2nd
Looking for a driver for 'EMMC'
chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 0 width 4 delay 9 rpapi_base 0x00030400
Downloading driver
Elapsed time: 0:23.293
Press any key to continue . . .
Thanks.
Old 06-10-2012, 17:17   #49 (permalink)
Member: 476075
Thanks Meter: 40
my i9100g gives logo.jpg draw failed. it is displayed on phone lcd. whats is the problem.
br
asif
Old 06-11-2012, 02:23   #50 (permalink)
Member: 1752435
Download this version:
OMAPFlash_1229_2ndlastt.rar
its the omap for i9000..copy the emmc_drv_ver416.bin and use it instead of the one you have..not sure it would work...but it seems the issue is with the emmc_drv
Old 06-11-2012, 05:54   #51 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 333
whats is the password
Old 06-11-2012, 10:16   #52 (permalink)
Member: 172448
Thanks Meter: 5
Hi
Mr Legija:
For gt-i9100g sleep mode,is it possible to convert Chinese locked bootloader to european or asian with unlocked boot ???
bcoz i repair boot successfully with this tool but already i am in CHINESE LOCKED BOOT & cant flash other fw to this phone (only chinese fw) .
whats a solution ???
tnx .
Old 06-11-2012, 10:33   #53 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,163
You can now access it via JTAG and play with it.
The Following User Says Thank You to legija For This Useful Post:
Old 06-11-2012, 15:05   #54 (permalink)
Member: 172448
Thanks Meter: 5
Which xloader i have select ? Xloader + or Xloader -
tnx
The Following User Says Thank You to Masoud.ebi For This Useful Post:
Old 06-12-2012, 09:19   #55 (permalink)
Member: 1752435
Mr. legija..been following this post for some times trying to get my phone back to life.. my phone came with the Canadian yakjuux firmware and I have posted the results before..do you think the omap flash is not working for me because of the omap4460 version since the older versions had incompatibility issues with some commands....or do i have a different set of hardware.. how do u think i should go about it if i use jtag..
Old 06-13-2012, 09:00   #56 (permalink)
Member: 1771105
Smile Wowwo nexus i9250 working again :)
Originally Posted by legija View Post
https://rapidshare.com/files/1168981...Flash_tuna.zip
GT-I9250:
Just execute *.bat file from this package.
Installing drivers first would be pretty smart idea too.
Enjoy !
Edit:
For i9100G phones which have ID 0xFFFFFFFE, download this archive, unpack and run *.bat file from root folder:
Thanks to R3IS
https://rapidshare.com/files/3960209...9_2ndlastt.rar
thanks mate i using my nexus 9250 again .) just tried few times and worked finally thanks ...
Old 06-14-2012, 13:02   #57 (permalink)
*Diablo*'s Avatar
Member: 59173
Sonork: 100.1585568
Thanks Meter: 222
Originally Posted by MUTUAL View Post
i m stil waiting for answer can some one tell me what to do? i have dead i9520 i can connect but always give error saying
EMMC eMMC DRIVER DEINIT COMPLETE
Download failed (final data response error): Remote: : Driver init error 0x00F
F8080 - MMC CONFIG FAILURE
Elapsed time: 0:05.453 (8730 bytes/s)
Operation FAILED (Remote: : Driver init error 0x00FF8080 - MMC CONFIG FAILURE)
Elapsed time: 0:18.531
did you solved ?
have same problem but address different
Old 06-15-2012, 00:27   #58 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 333
Originally Posted by *Diablo* View Post
did you solved ?
no i did not no one tell me what to do now stil stuck same probelm
Old 06-15-2012, 21:59   #59 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,189
with out Battery Program Run ok and Repair Done ,but nothing on LCD
With Battery i able see Download Screen but Phone Stuck there no Ask drivers ETC ,
can any one Help in Repair ?
Old 06-17-2012, 09:31   #60 (permalink)
Temporary banned !!
Member: 1151970
Sonork: 100.1597000
Thanks Meter: 376
add more coming soon here sir
next update taem Sony Ericsson Xperia to usb add more here
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
I am looking for information about GSM-CABLES.NE DUPOND Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 08-03-1999 15:29
Selling original Nokia DAU9P cable TheDon Main Sales Section 0 07-21-1999 15:44
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.44554 seconds with 9 queries
