Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 08-11-2012, 23:51   #106 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,407
Originally Posted by michaelmotes View Post
I have I9250 with corrupt imei, just shows generic 00499...
I am willing to solder on the JTAG pins but this box does not yet have IMEI repair feature via resurrection dll for I9250. How else can I repair IMEI?
Hi
Imei Repair Not Supported By Riff-Box...
But.Please Contact Me Via Sonork
I'll explain to you how you can repair imei
Old 08-11-2012, 23:55   #107 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,407
Originally Posted by mrx3net View Post
any help with this
stuck here Found device (omap usb)
Waiting for 2nd
Hi
It's Mean You Need Check HW.....
Usually is eMMC Problem
But..Please Don't use Battery or Power Supply
Just Connect Usb and Run Script
Maybe you need Try several times
Old 08-11-2012, 23:56   #108 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,407
Originally Posted by Softking View Post
i faced like same prob
after i ressurect with riff and medusa
but phone still hang on logo
i also need solution for this
Hi
Did You Flash Phone Via Odin....?
if odin hang on flashing any partition,,,Please Contact me via sonork
Old 08-11-2012, 23:57   #109 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,407
Originally Posted by BouRRi_GSM View Post
what about i9003 !!!
Hi
What's You need for i9003? Repair via USB?
Jtag interface already supported dead boot..
Old 08-11-2012, 23:59   #110 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,407
Originally Posted by QASSEM View Post
hi
first tnx for this solution
now my fone is only on start and doesnt do to download mode see the pic
Hi
Some Case Need Reflash Phone After Repair..Did You Flash Phone..?
Old 08-12-2012, 00:20   #111 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,407
Hi
Unlocking Procedure Not Supported By Riff
Old 08-12-2012, 13:31   #112 (permalink)
Member: 1796693
Smile i know, i know, i know this is gsmhosting.com but...
is there anything like this for cdma model?
thank you
Old 08-12-2012, 21:13   #113 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 265
Originally Posted by zaidi_mobile View Post
plz help riff team
samsung galaxy s3 i9300 unlock possble?????
Just root and unlock with another box. Very easy job.
RIFF is for more intricate problems
Old 08-13-2012, 09:28   #114 (permalink)
Member: 90307
Thanks Meter: 11
Originally Posted by BABAK NURI View Post
Hi
it doesnt recognize by pc or by odin i cant see the port to flash it help me how to reflash it tnxxx
Old 08-13-2012, 21:12   #115 (permalink)
Member: 172567
Thanks Meter: 55
by the way, none of the other box can repair efs from i9300 to fix imei (even the original one). all the tools works with android till 2.3.6, in phones with higher versions if you try to fix imei or efs you get the 0049.... and there's no way to fix it yet.
Old 08-14-2012, 07:03   #116 (permalink)
Member: 1796140
Help
I get stuck after "waiting for second, please help.
OMAPFlash v4.15 (Aug 12 2011)
-v
Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t at line
1
-omap 4
-t 36000
-p OMAP4460_TUNA_8G_HS_PRO
-2
chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO
chip_download EMMC Targets\Projects\tuna\sbl.img
command cold_sw_reset
Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t
@Targets\Projects\tuna\omap4460_tuna_hs_pro.txt
Looking for device (omap usb)
Please turn off device
Please turn on device
Waiting for device (omap usb)
Requesting ASIC id
AsicId items 05
AsicId id 01 05 01 44 40 07 01
AsicId secure_mode 13 02 01 00
AsicId public_id 12 15 01 B0 E3 EB 46 24 23 64 B9 9F B7 3F FB 28 AB 38
3 38 9D A5 B7
AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2
5 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC
AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC
Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS
Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si
ned.2nd.hs_pro
Entering parameter filemapflash2nd.txt at line: 46
-pheriphalboot_reopen
Reading board configuration file Targets\Configurations\configuration_omap4460
tuna_8g.txt
Reading definition file .\targets\definitions\definitions_omap4.txt
-board_config Targets\Configurations\configuration_omap4460_tuna _8g.txt
Leaving parameter filemapflash2nd.txt
Sending size of second file (0x000071B0 bytes)
Transferring second file to target (0x71B0 bytes)
Closing boot connection
Waiting for 2nd
Unknown status message '?#??' during peripheral boot (waiting for 2nd)
ress any key to continue . . .
Old 08-14-2012, 07:55   #117 (permalink)
Crazy Poster
Member: 91973
Thanks Meter: 3
please help
it s stuck on writing mlo file
Old 08-14-2012, 08:30   #118 (permalink)
Crazy Poster
Member: 91973
Thanks Meter: 3
nobody help?
nobody help? because not work at mine this solution
Old 08-16-2012, 05:59   #119 (permalink)
Member: 1798316
Still not working for my unresponsive i9250
I am getting this message. Any idea on how to deal with it?
-v
: 1
-omap 4
-t 36000
-2
-rxtx_trace
Requesting ASIC id
00130-000-TX 4 raw bytes: 03 00 03 F0 '????'
AsicId items 05
AsicId public_id 12 15 01 3D 1D 5B 09 13 EF 70 5E 6B 29 6D 2B 17 C2 DE
5C D8 C5 DB C0
25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC
00130-001-TX 4 raw bytes: 02 00 03 F0 '????'
gned.2nd.hs_pro
_tuna_8g.txt
00130-002-TX 4 raw bytes: B0 71 00 00 '?q??'
00130-003-TX 29104 raw bytes: B0 1C 00 00 00 4D 00 00 00 00 00 00 00 00 00 00
'?????M??????????' ...
Waiting for 2nd
00463-004-TX ACK
00571-005-RX: 4 raw bytes: 78 ED 0D 00 'x???'
Unknown status message 'x???' during peripheral boot (waiting for 2nd)
Press any key to continue . . .
C:\Users\Juan Carlos\Downloads\OMAPFlash_tuna\OMAPFlash>GOTO __loop
-v
: 1
-omap 4
-t 36000
-2
-rxtx_trace
Requesting ASIC id
AsicId items 05
5C D8 C5 DB C0
gned.2nd.hs_pro
_tuna_8g.txt
Waiting for 2nd
00463-004-TX ACK
00571-005-RX: 9 raw bytes: 78 ED 9B 02 18 FE 44 00 00 'x?????D??'
Unknown status message 'x?????D??' during peripheral boot (waiting for 2nd)
Old 08-16-2012, 14:32   #120 (permalink)
Crazy Poster
Member: 1770014
Sonork: We can do Any Price
Thanks Meter: 16
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.33, JTAG Manager Version: 1.44
Selected Resurrector: [Samsung i9100 V1.0.4582.4854]
Connecting to the dead body...OK
Detected dead body ID: 0x4BA00477 - CORRECT!
Set I/O Voltage reads as 2.81V, TCK Frequency is 800 kHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB)
Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB)
Flashing the dead body...
ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...OK
ERROR: Stopped due to multiple communication errors. Terminating at 0x000000000000
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
I am looking for information about GSM-CABLES.NE DUPOND Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 08-03-1999 15:29
Selling original Nokia DAU9P cable TheDon Main Sales Section 0 07-21-1999 15:44
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.51172 seconds with 9 queries
