02-16-2013, 06:10 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 263548 Status: Offline Thanks Meter: 24 | Unbrick htc one s problem.... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x000000E1 - WRONG!!! ERROR: Current ID does not belong to the HTC OneS (PJ4010000) family. Help.... Thanks |
02-16-2013, 12:27 | #4 (permalink) |
Member: 263548 Status: Offline Thanks Meter: 24 | Thank for reply no luck Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x407910E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. Help..... |
02-16-2013, 13:07 | #5 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: Hanoi, Vietnam
Member: 1012390 Status: Offline Thanks Meter: 95 | Quote:
You need do it with your patience One S often get this Error, you need charge the battery by power supply for 15-20 minutes, then try again. Here is my result in Vietnamese forum, you can see pictures and log: HTC Ville (One S S4) T-Mobile repair boot OK HTC One S repair boot - Super CID - Repair IMEI OK | |
The Following User Says Thank You to Hoayeu105 For This Useful Post: |
02-18-2013, 09:01 | #6 (permalink) | |
Member: 263548 Status: Offline Thanks Meter: 24 | Quote:
Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x407910E1 - CORRECT! Set I/O Voltage reads as 1.78V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init. help..... @Hoayeu105 thank for reply | |
02-18-2013, 12:23 | #7 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Please start using RIFF error codes database ! http://forum.gsmhosting.com/vbb/f634...-more-1476587/ |
The Following User Says Thank You to legija For This Useful Post: |
02-19-2013, 00:02 | #8 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
Please Read : RIFF JTAG Box FAQ - Detected dead body ID: 0x000000E1 - WRONG!!! -------- Also Plz Connect Phone to RIFF-Box,Then Contact Me Via Sonork... I teach you How You Can Solve Your Problem | |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
02-20-2013, 11:46 | #9 (permalink) |
Member: 263548 Status: Offline Thanks Meter: 24 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x407910E1 - CORRECT! Set I/O Voltage reads as 1.78V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 2 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. no luck get many error... Any idael?? |
