08-10-2011, 14:05 | #1 (permalink) |
Junior Member Join Date: Aug 2011 Location: Russia, Moscow Age: 40
Member: 1632447 Status: Offline Thanks Meter: 0 | riffbox.org connection problems We have bought Riff Box Jtag about 3 weeks ago and had our internal routing problems in connection with your site (which are needed for updates, required for device operation). Now they are solved but after that it seem that our IP ad******* become blocked by riffbox.org side: to test our routing configuration we had used traceroute utility, but tests on third PC shows: after traceroute attempt client IP address is blocked on riffbox.org side - I have no pings. So, does it possible to unblock my IP address: 1) 83.167.123.73 2) 213.33.220.118 |
08-11-2011, 19:05 | #2 (permalink) |
Member: 1632447 Status: Offline Thanks Meter: 0 | I steel have this problem, so now i'm trying to download Riff software over mobile phone (GPRS), but it is too slow. Traceroute results for my ordinary connection (not phone): $ traceroute jtagbox.com traceroute to jtagbox.com (46.4.102.38), 30 hops max, 60 byte packets 1 dima-host.local (10.16.1.37) 1.116 ms 2.107 ms 2.338 ms 2 172.21.0.1 (172.21.0.1) 9.526 ms 9.464 ms 9.479 ms 3 10.244.3.142 (10.244.3.142) 13.111 ms 13.032 ms 13.135 ms 4 188.123.255.41 (188.123.255.41) 9.030 ms 8.995 ms 13.004 ms 5 188.123.255.41 (188.123.255.41) 13.099 ms 13.717 ms 13.877 ms 6 62.117.74.109 (62.117.74.109) 12.453 ms 11.184 ms 11.138 ms 7 Cus-SR-78.comcor.ru (62.117.100.78) 8.231 ms 8.097 ms 12.901 ms 8 zhu-vl.comcor.ru (62.117.100.186) 59.806 ms 60.005 ms 59.970 ms 9 r1fra1.core.init7.net (80.81.192.67) 70.194 ms 69.354 ms 69.463 ms 10 gw-hetzner.init7.net (82.197.166.86) 65.100 ms 65.011 ms 64.977 ms 11 hos-bb1.juniper2.rz14.hetzner.de (213.239.240.247) 69.376 ms hos-bb1.juniper1.fs.hetzner.de (213.239.240.242) 68.979 ms 67.918 ms 12 hos-tr4.ex3k9.rz14.hetzner.de (213.239.224.234) 70.172 ms hos-tr2.ex3k9.rz14.hetzner.de (213.239.224.170) 66.998 ms hos-tr4.ex3k9.rz14.hetzner.de (213.239.224.234) 67.012 ms 13 * * * 14 * * * <...> Seems that connection goes to nowhere Maybe there is any support email for such problems? |
08-17-2011, 11:46 | #4 (permalink) |
Member: 1632447 Status: Offline Thanks Meter: 0 | Hello! Thank you for granting access, but in traditional meaning nor tracerouting, nor accepting of offered by supporting standard ICMP traceroute requests are not considered as sniffing. From other side I have tried to make transparent FTP proxy for software update when I had direct connection problems (because JTAGManager software haven't any proxy connection settings and does not use system-wide settings), maybe you had suspected sniffing in such attempt? Now I have access to jtagbox.com, and can download drivers and JTAGManager, but I can't update them. My firewall and antivirus settings are based on corporate rules and I can't change them. But I have found over internet newer software versions of JTAGManager and resurrector files, so I succesfully resurrected Galaxy S I9000. But now I need to change firmware on Galaxy S II, and I haven't found enough new software to supports such configuration. Have you any additional software distribution source, or maybe you have additional firewall rule for software update? |
08-17-2011, 13:18 | #9 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | What About This: Connecting to the Updates Server...OK Getting Updates Information from the Server...OK and downloading last for ever Share If U Care |
08-17-2011, 21:40 | #11 (permalink) |
Freak Poster Join Date: Sep 2005 Location: saudiarabia/india
Member: 185396 Status: Offline Sonork: 100.1618832 Thanks Meter: 33 | Riff box showing this error ERROR: The DLL was not accepted: "Samsung_I9100.dll" ERROR: The DLL was not accepted: "SE_X8.dll" Found and Initialized: 8 New and 0 Old External Repair Pack(s) how can solve this error |
08-18-2011, 11:53 | #12 (permalink) |
No Life Poster Join Date: Nov 2006 Location: maldives
Member: 389862 Status: Offline Sonork: guy_askali Thanks Meter: 54 | update problem i have install riff box 1st time and update all resurrection files and i got problem pc again i format my pc and install riff box i can't see inside update resurrection files place explain me how to get update files thank you Askar Ali |
08-18-2011, 12:00 | #13 (permalink) |
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | Bro After first Install u need to go to Box Service tab and press ( Check For Updates ) wait till new window open and tell u to download latest version of Manager ( like where i Stuck now for 5 Days ) and after download new manager go again to same tab and press same buuton to get all DLL to download and after that u get it done Share If U Care |
08-18-2011, 12:13 | #15 (permalink) |
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | I stop my Antivirus and Stop Firewall and same result I just Need to Work not to Waste your time + Mine too Share If U Care |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
