04-17-2014, 12:58 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 774169 Status: Offline Thanks Meter: 123 | v9c --- dead i used v9 dll to resurrect the handset , but after resrrection handset is swithed on with dotted screen . not going in ftm mode which dll is is required to resurrect the phone ??? regards suraj |
04-17-2014, 13:44 | #2 (permalink) |
Member: 774169 Status: Offline Thanks Meter: 123 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [ZTE V9 V1.0.0.0] Connecting to the dead body...OK Detected dead body ID: 0x503C00E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Flashing the dead body...OK WARNING: Programming Error (0x24) at 0x000000260000 is handled as Cut Excess. Resurrection complete! STILL IS NOT BOOTING ONLY RED LIGHT IS BLINKING AT THE TOP |
04-17-2014, 15:13 | #3 (permalink) |
Member: 774169 Status: Offline Thanks Meter: 123 | i erased it full . now its showing port . i treid to install v9c software using sales ----- software , but it says wrong software . then i tried to install v9 software ------ now its on but its now showing FTM mode after that i treid to install v9c software again , still it says wrong software any expert have answer to this suraj |
04-18-2014, 09:11 | #6 (permalink) |
Member: 774169 Status: Offline Thanks Meter: 123 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [ZTE V9 V1.0.0.0] Connecting to the dead body...OK Detected dead body ID: 0x503C00E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x34010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF WARNING: Programming Error (0x24) at 0x000000260000 is Ignored. ERROR: DCC Loader has reported Error Code = 0x28 (0x000000). Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover... i try with v9c.bin . still its giving error , how to recover this phone . regards |
04-18-2014, 10:12 | #7 (permalink) |
Member: 774169 Status: Offline Thanks Meter: 123 | BABAK NURI --- Legiga --- AK singh -- Ren pls view this thread MAsters / product supportter pls view this thread . kindly give attention to this . waiting waiting wating ....... |
04-19-2014, 04:58 | #8 (permalink) | |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | Quote:
but seems to be power problem check power use usb + battery wire length must be shortest as to save data loss press power on while writing or resurrection check advance setting see nand writing video in sticky thread don't use cut excess setting ,,overlap it Error explains : May happen if target is currently in some unrecoverable h/w state or if memory controller is not properly initialized or due to some other reasons. Shall not happen since it is DCC Loader’s task to initialize and communicate with memory controller properly. Can happen if target has a damaged memory chip br, Last edited by ~AKSingh~; 04-19-2014 at 05:06. | |
04-19-2014, 05:11 | #9 (permalink) | |
after halting a hardware ref : Detected dead body ID: 0x503C00E1 use ID to search dll in resurrection tab various dlls can be used for same hardware. use "analyze jtag chain" function tab to find out CPU this will help in case Direct jtag access (plugin) needed to read or write a hardware br, | |
04-19-2014, 06:27 | #10 (permalink) |
Member: 774169 Status: Offline Thanks Meter: 123 | Thanks to Singh sir for responding . sir have breif look again . 1. i erased with v9 dll 2. resurrected with v9 dll . 3. flashed with v9 software (optus) handset swithes on, show andriod logo , then again goes to FTM mode . i think that indicates that hardware is ok --------------------------------------------- 2nd case 1. erased with v9 dll 2. tried to write v9c dump its giving the above error . so i think its dll error . i try the above things mentioned by you (Singh sir ) and report regards suraj |
04-20-2014, 09:07 | #12 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 | lol you have erased handset how can you expect handset will get in normal position note : resurrection is for boot repairing its not a full flash after resurrection handset will get Normal ON only if resurrection image matches the flash chip firmware what to do now ???? ..... now flash the handset with ZTE v9c original firmware and Download tool use search button now br, Last edited by ~AKSingh~; 04-20-2014 at 18:42. |
