06-08-2018, 10:01 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | what is this error (Out of Memory) Last edited by legija; 06-08-2018 at 11:41. |
06-08-2018, 11:39 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Could You please post specs of Your PC ? (RAM, system disk free space, CPU) |
The Following User Says Thank You to legija For This Useful Post: |
06-09-2018, 08:07 | #3 (permalink) | |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
06-09-2018, 11:11 | #4 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | You should install 64 bit version Windows for start, to be able to use 4GB of RAM. Otherwise error very strange, as JTAG Manager RAM footprint is just 130MB. As this is windows problem, here is proposed solution by Microsoft: https://windowsinstructed.com/fix-no...-this-command/ Last edited by legija; 06-09-2018 at 11:18. |
06-10-2018, 08:56 | #5 (permalink) | |
Dear Respected sir. I really appricate Riff Team. But i am using that system very well and all box working nice. and i have alot of data. It will be almost impossible for me to install new oprating system . And i already tried that solution from Mircrosoft and it didnt work. Is it possible that u can add in next software which will support 32BIT also. | |
06-10-2018, 10:10 | #6 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, I'm not sure if this is JTAG Manager problem, or simply some windows component related to network access. I was unable to reproduce it on testing setup. Please contact me via QQ tomorrow, we need to try to find exact problem which causes this. |
06-10-2018, 11:45 | #7 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | All right. I will . I tried it on another system but still same error. and that system also have 32BIT windows. If you 100% sure that it will work on 64 BIT , i can try to orginaz another pc for only RIFF JTAG.. |
06-10-2018, 13:20 | #8 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | Here is the dll reason for this error, couple of dll currupt on riff support and I m sure you have one or more dll in riff folder tomorrow I will post currupt DLL list. |
06-10-2018, 15:25 | #9 (permalink) | |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
Please do this: 1. Start JTAG Manager, then execute Task Manager -> Resource Monitor -> Memory tab. 2. Find JTAGManager.exe and select it 3. Make screenshot with visible columns "Commit" and "Working Set" 4. Copy JTAG Manager to empty folder (without DLL-s and repairpacks) 5. Repeat steps 1 to 3. | |
06-11-2018, 11:50 | #10 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Spain
Member: 840762 Status: Offline Thanks Meter: 166 | Close riff app, reconnect box, working for me! (After 3 times I can open "connect server" without "out memory error" and can put licence) now working fine. I have 8gb of ram this is not the problem... If more errors for "memory out" in any procedure, restart program and update riff box firmware! BR |
06-11-2018, 12:01 | #11 (permalink) | |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | "Out of memory" is Windows system error message, related to Desktop manager. https://support.microsoft.com/en-us/...e-number-of-pr Quote:
06-11-2018, 16:08 | #12 (permalink) | |
Member: 669673 Status: Offline Thanks Meter: 301 | Quote:
1. Huawei_Honor4C_CHM_U01_ISP.dll 2. Huawei_P6_C00_ISP.dll 3. Motorola_XT1022_ISP.dll 4. Motorola_XT1034_ISP.dll 5. Samsung_J320A_ISP.dll could be more on support site but i faced error in listed dll. Riff team please check its. | |
06-20-2018, 10:35 | #14 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | having same issu i5 / free disk /2g ram /fresh copy of windows only after connect/disconnect 3 times to be able to get license |
06-20-2018, 13:07 | #15 (permalink) | |
I have found something. If i put only some files in Resurrectors then its fine but when i put more files then it start giving me error. | |
