01-24-2014, 17:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | what is solution to this error Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC Sensation (PG5813000) V1.0.4557.1879] Connecting to the dead body...OK Detected dead body ID: 0x104210E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (MLL00M, 0x000090000000 Bytes = 2.25 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (MLL00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000000000000 |
01-24-2014, 17:30 | #2 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | RIFF JTAG Box FAQ - ERROR: Timeout while waiting for DCC Loader response. Try to Lower RTCK Value ...try 8 , 4 , 2 etc |
01-25-2014, 11:29 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Guys @ skyulock You need just check wires + power @spagman This is correct manual :RIFF JTAG Box FAQ - ERROR: Failed due to multiple communication errors. |
01-25-2014, 11:35 | #4 (permalink) |
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC Sensation (PG5813000) V1.0.4557.1879] Connecting to the dead body...OK Detected dead body ID: 0x104210E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (MLL00M, 0x000090000000 Bytes = 2.25 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (MLL00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body...OK Resurrection complete! thanks bro is work |
The Following User Says Thank You to skyulock For This Useful Post: |
