Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 06-24-2011, 13:02   #1 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
Wildfire vibrates 3 times with green LED
Hi everybody:
I got a Wildfire,it's brand new,if i try to power it on it vibrates 3 times with a green light in LED notification.When i try bootloader mode it does nothing and if connected to USb it asks for "Qualcomm CDMA Technologies MSM" driver.
Phone hardware is checked and there are no sign of physical damage to the phone.Is this phone bricked?what shall i do with it?
Old 06-24-2011, 13:26   #2 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
Connect to RIFF and press "Resurrection" button.
Your phone has deleted modem boot part.
Old 06-26-2011, 16:50   #3 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
I did resurection and process completed as you see in the log below successfully but still its in the same condition.I did just the first option,neither CID nor imei checked.Please help.
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.25* JTAG Manager Version: 1.33
Selected Resurrector: [HTC WildFire]
Connecting to the dead body...OK
Detected dead body ID: 0xC01B30E1 - CORRECT!
Set I/O Voltage reads as 2.59V* TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB)
Flashing the dead body...OK
Resurrection complete
Old 06-26-2011, 21:29   #4 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
Please help me.How can i do repair CID if it's really needed?Anyone who has repired such phone please share idea here.
Old 06-27-2011, 02:40   #5 (permalink)
Member: 1454100
Thanks Meter: 28
Try flashing with a dump of a HTC buzz .. if not click repair imei zone and input the imei of the phone ...
Sent from my xxx using Tapatalk.
Old 06-27-2011, 07:43   #6 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
Shall i read the dump with riff?do you have any dump file available please?
Old 06-27-2011, 09:38   #7 (permalink)
Member: 1454100
Thanks Meter: 28
No point reading your phone if its dead .... have a look in the link exchange program I never use it so don't know :-) but that should be what you need if not maybe hardware fulety
Old 06-28-2011, 08:27   #8 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
Look at the picture below this is all i did second time but phone still in the same condition.Phone hardware is ok 100%
Old 06-28-2011, 10:19   #9 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Does it still ask for Qualcomm driver ?
Old 06-28-2011, 14:48   #10 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
yes it asks the same driver
Old 06-28-2011, 17:49   #11 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Something wrong
Do this, please :
1. Select HTC Wildfire
2. Go to "Plugins" TAB and Activate "QUALCOMM . . ." plugin
3. Click "Get partitions from device"
4. Click "Check for Blank"
Post results here.
Old 07-01-2011, 19:16   #12 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
This is Get partition:
And this is check for blank:
Here is the operatin log:
Firmware Version: 1.25, JTAG Manager Version: 1.33
Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
Reading FLASH1 address space from 0x00040000 to 0x00040FFF
Completed in 00:00:00.015 (Average Transfer Rate: 139810133.27 kB/s)
Detected NAND Page = 0x0800 bytes
Detected NAND Block = 0x00020000 bytes
Partition Table is found in block: 0x0002
Total quantity of listed partitions: 0x0010
Detected the HTC Partition.
The SIMLOCK Zone is not Found.
Checking which Partition is blank...COMPLETE!
Following partitions are found to be completely blank:
  Partition: QCSBL at 0x00140000..0x001BFFFF (0x000A..0x000D)
  Partition: OEMSBL1 at 0x001C0000..0x0027FFFF (0x000E..0x0013)
  Partition: OEMSBL2 at 0x00280000..0x0033FFFF (0x0014..0x0019)
  Partition: HTC at 0x00340000..0x0053FFFF (0x001A..0x0029)
  Partition: AMSS at 0x00540000..0x01D3FFFF (0x002A..0x00E9)
  Partition: EFS2 at 0x01D40000..0x022BFFFF (0x00EA..0x0115)
  Partition: FOTA at 0x022C0000..0x023BFFFF (0x0116..0x011D)
  Partition: RESERVED at 0x023C0000..0x023FFFFF (0x011E..0x011F)
  Partition: APPSBL at 0x02400000..0x024BFFFF (0x0120..0x0125)
  Partition: MISC_MFG at 0x024C0000..0x024FFFFF (0x0126..0x0127)
  Partition: WLAN at 0x02500000..0x0253FFFF (0x0128..0x0129)
  Partition: SPLASH1 at 0x02540000..0x0265FFFF (0x012A..0x0132)
  Partition: SPLASH2 at 0x02660000..0x0281FFFF (0x0133..0x0140)
  Partition: APPS at 0x02820000..0x0771FFFF (0x0141..0x03B8)
  Partition: EXT_ROM at 0x07720000..0x07FFFFFF (0x03B9..0x03FF)
Old 07-01-2011, 20:41   #13 (permalink)
legija's Avatar
Member: 256342
Sonork: None
This procedure is tested with HTC Wildfire :
1. Erase full flash
2. Press "Resurrection", enter new IMEI, SuperCID and tick "HTC Partition"
3. Enter bootloader and flash the phone with firmware
If phone hw is ok, this will resolve any software based problems. Of course, if HW is not ok, You cannot fix it with software.
Check "Important Manuals" sticky topic for details about erasing flash and CID update.
Old 07-04-2011, 14:27   #14 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
I did as you said but during erase i got following error as you see in the picture,i ignored and got same error on diffrent erase ad*******.Anyway i ignored the errors and did the repair and still it vibrates,plz check.
Old 07-05-2011, 12:28   #15 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Of course it will vibrates. Now You need to enter download mode and update ROM.
If You can not enter download mode, check volume keys flex cable and power button.
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.21336 seconds with 9 queries
