Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 10-23-2012, 10:25   #1 (permalink)
hape_tenso's Avatar
Member: 1199611
Thanks Meter: 23
x10 dcc write help
Is this the right setting ?
I use dump file from here
result, the phone is only vibrate when powered on.
i already write TA and repair imei.
expert, please help...
Old 10-23-2012, 10:41   #2 (permalink)
hape_tenso's Avatar
Member: 1199611
Thanks Meter: 23
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.33, JTAG Manager Version: 1.43
Selected Resurrector: [SE X10i V1.00]
Connecting to the dead body...OK
Detected dead body ID: 0x202400E1 - CORRECT!
Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Settings Code: 0x21020000000000000000000040000000
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55B3 (1024MB)
Writting FLASH2 memory from 0x000000000000 to 0x00003FFFFFFF
Completed in 00:55:48.094 (Average Transfer Rate: 322.97 kB/s)
Still vibrate only
Old 10-23-2012, 10:52   #3 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
RIFF JTAG Box FAQ - JTAG Manager - DCC Read/Write TAB
The Following 2 Users Say Thank You to legija For This Useful Post:
Old 10-23-2012, 12:27   #4 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
I use dump file from [result, the phone is only vibrate when powered on.
99.9% is Hardware Problem,like lot of other X10i
The Following User Says Thank You to BABAK NURI For This Useful Post:
Page generated in 0.14952 seconds with 8 queries
