12-17-2011, 19:17 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 781 | ZTE MF180 No response from the RIFF Box after write the wrong firmware have a nice day to all stuff of riffbox well we shorten a request regarding my problem Brand : ZTE Model : MF180 Problem : dead boot Lock network : lock on smart telecom ( Philippines ) Back up : i already made a back up ( encase i get problem ) History taken : im just simple resurrect the modem to repair the dead boot, after i repair and flash the dump file as the manual. but the problem is i smock a wrong firmware of my modem instead of MF180, i smock a dump file for MF637. i did not notice about that, and flashing completely without my knowing that i write the wrong file , so i tried to power or insert the modem into ant usb port or my pc but nothing happen it wont detect the modem driver or any sign for connecting the new device in usb port now the big problem is after flashing i try to resurrect again and write to original file ( my back up ) but when i click the resurrection i get this error even i changing speed from lower to higher here is the log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [USB Modem MF180] Connecting to the dead body...OK Detected dead body ID: 0x401200E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 2 MHz] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. i also check the ID for this modem under JTAG/write tab and here is the log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [USB Modem MF180] Connecting to the dead body...OK Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Model selected: ZTE - USB Modem MF180 Detected dead body ID: 0x401200E1 now i try to write direct plugin using the new update and changing the base address from any number there to get some reaction but im not lucky here is the log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Target: [ARM926E, 2.60V, TAP0] Connecting to the ARM926E target...OK Detected dead body ID: 0x401200E1 - IGNORED! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 20 kHz] Resetting and Halting target...OK R0 = 0x00008000 R6 = 0x78000028 R12 = 0x00000090 R1 = 0x00000002 R7 = 0x78000890 R13 = 0x78016F28 R2 = 0x00000014 R8 = 0x00000000 R14 = 0x4001E400 R3 = 0x0000CC1F R9 = 0x00000000 R15 = 0xFFFF03D8 R4 = 0x80000000 R10 = 0x00000000 CPSR = 0x400000D3 R5 = 0x00000002 R11 = 0x78000028 Connecting to the NOR Memory based at 0x40000000...FAILED ERROR: No response from the RIFF Box. here is the screen shot the address from manual base on this and i also try to erase the flash but still no response here is the log of erasing Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [USB Modem MF180] Connecting to the dead body...OK Detected dead body ID: 0x401200E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 40 kHz] Settings Code: 0x0200010000000000000000000000 Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. here is the screen shot i also try to set the memory base to 0x000000 but still the same problem here is the log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Target: [ARM926E, 2.60V, TAP0] Connecting to the ARM926E target...OK Detected dead body ID: 0x401200E1 - IGNORED! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 20 kHz] Resetting and Halting target...OK R0 = 0x00008000 R6 = 0x78000028 R12 = 0xFFFF2C2B R1 = 0x00000002 R7 = 0x78000890 R13 = 0x78016F28 R2 = 0x00000014 R8 = 0x00000000 R14 = 0x4001E400 R3 = 0x0000CC2B R9 = 0x00000000 R15 = 0xFFFF03E0 R4 = 0x80000000 R10 = 0x00000000 CPSR = 0x800000D3 R5 = 0x00000002 R11 = 0x78000028 Connecting to the NOR Memory based at 0x00000000...FAILED ERROR: No response from the RIFF Box. hope my simple explanation as clearly at your side if this short explanation regarding my problem not clearly well. i can make also a short video waiting for your reply @ legija sir i hope don't answer me use search button or sticky thread inside our forum or i already did this many many times be fore i post GSM-Forum - Search Results some post are not answered clearly |
12-19-2011, 12:03 | #3 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, This is specific problem, caused by alien code flashed into modem. It prevents CPU to enter required reset state. I remember few users had something similar with MF627, and it was resolved by shorting CS0 to gnd prior to booting. I think in this case, You'll need to find CS0 TP, thus disabling flash chip while starting up CPU core. Since I dont have schematics for this modem, I cant help You further with this. |
The Following User Says Thank You to legija For This Useful Post: |
12-20-2011, 06:13 | #4 (permalink) |
Member: 302596 Status: Offline Thanks Meter: 781 | thanks for your shorten clue, now atlest we have guide that the software has no power to repair, i will try to find the schematic of this modem, hopefully im locky to find it, r somebody have good mind to share it thanks anyway |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
