06-19-2013, 13:42 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: India
Member: 1505057 Status: Offline Thanks Meter: 38 | zte s1602 16mb dead Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [ZTE S1602 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 1.82V, TCK Frequency is 4 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip, ID: 0x0000/0x0000 (16MB) ERROR: Selected FLASH Chip was not initialized by the DCC Loader. i also write dump but not taking Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [ZTE S1602 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 1.82V, TCK Frequency is 4 MHz Settings Code: 0x3A010900000000000000000001000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip, ID: 0x0000/0x0000 (16MB) ERROR: Main data file size is less than requested to flash to main. |
