10-23-2013, 05:44 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | IN TRING TO ERASE M GETTING ERROR Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [QSC1100 X14 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x17010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init. |
10-23-2013, 09:51 | #5 (permalink) |
Freak Poster Join Date: Sep 2009 Location: india
Member: 1129899 Status: Offline Sonork: 100.1625475 Thanks Meter: 16 | chek this how to flash Direct JTAG access method video zte s160/161 done http://forum.gsmhosting.com/vbb/f634...9/#post9824143 |
10-24-2013, 11:46 | #8 (permalink) | |
Member: 1129899 Status: Offline Sonork: 100.1625475 Thanks Meter: 16 | Quote:
The Following User Says Thank You to singhdharmendr For This Useful Post: |
10-24-2013, 14:44 | #10 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | hi this error Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Target: [QSC1100, 1.80V, TAP0] Connecting to the QSC1100 target...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resetting and Halting target...OK R0 = 0x00000000 R6 = 0x00000000 R12 = 0x00000000 R1 = 0x00000000 R7 = 0x00000000 R13 = 0x00000000 R2 = 0x00000000 R8 = 0x00000000 R14 = 0x00000000 R3 = 0x00000000 R9 = 0x00000000 R15 = 0xFFFFFFE8 R4 = 0x00000000 R10 = 0x00000000 CPSR = 0x00000000 R5 = 0x00000000 R11 = 0x00000000 Connecting to the NOR Memory based at 0x00000000...FAILED ERROR: Failed to Initialize Memory Controller. Code: 0x23 |
10-24-2013, 14:46 | #11 (permalink) | |
