07-19-2013, 08:16 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: in your Heart
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | zte s161 Wrong response code from the RIFF Box: 0x45 Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [ZTE S160 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 1.82V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x24010000000000000000000000800000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 solution please |
07-19-2013, 08:18 | #2 (permalink) |
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | with qsc1100 also same error Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [QSC1100 X14 NOR V1.0.0.0] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 1.82V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x24010000000000000000000000800000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 |
07-19-2013, 10:10 | #3 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | Last edited by .::TEJARAM::.; 07-19-2013 at 10:16. |
The Following User Says Thank You to .::TEJARAM::. For This Useful Post: |
