zte s165 became dead while unlocking
still dead after resurrection and writing dump.
[11/2/2013 4:31:11 PM] [START OPERATION_ID = RESURRECT]
[11/2/2013 4:43:25 PM] Open serial port...OK
[11/2/2013 4:43:25 PM] Connecting to the RIFF Box...OK
[11/2/2013 4:43:25 PM] Firmware Version: 1.37, JTAG Manager Version: 1.54
[11/2/2013 4:43:25 PM] Selected Resurrector: [ZTE S165 V1.0.4609.43971]
[11/2/2013 4:43:25 PM] Connecting to the dead body...OK
[11/2/2013 4:43:25 PM] Detected dead body ID: 0x122C80E1 - IGNORED!
[11/2/2013 4:43:25 PM] Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK
[11/2/2013 4:43:25 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX]
[11/2/2013 4:43:25 PM] Resurrection sequence started.
[11/2/2013 4:43:25 PM] Establish communication with the phone...OK
[11/2/2013 4:43:25 PM] Initializing internal hardware configuration...OK
[11/2/2013 4:43:25 PM] Uploading resurrector data into memory...OK
[11/2/2013 4:43:25 PM] Starting communication with resurrector...OK
[11/2/2013 4:43:25 PM] Detected an Initialized FLASH1 Chip, ID: 0x0001/0x007E (8MB)
[11/2/2013 4:43:25 PM] WARNING: No Data for the current NOR Chip. Selected default Data for the NOR Chip with IDs: 0x0020/0x88C0
[11/2/2013 4:43:25 PM] Flashing the dead body...OK
[11/2/2013 4:43:25 PM] ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK
[11/2/2013 4:43:25 PM] Resurrection complete!
[11/2/2013 4:43:25 PM] [FINISH OPERATION_ID = RESURRECT]
[11/2/2013 4:13:08 PM] [START OPERATION_ID = DCC_WRITE_MEMORY]
[11/2/2013 4:13:08 PM] Current Settings:
[11/2/2013 4:13:08 PM] -----------------
[11/2/2013 4:13:08 PM] Address: 000000000000
[11/2/2013 4:13:08 PM] Length: 000000800000
[11/2/2013 4:13:08 PM] Address Space: ROM1
[11/2/2013 4:13:08 PM] AutoFullFlash: CHECKED
[11/2/2013 4:13:08 PM] Use End Address: UNCHECKED
[11/2/2013 4:13:08 PM] ECC Module Enabled: UNCHECKED
[11/2/2013 4:13:08 PM] Image File is Used: UNCHECKED
[11/2/2013 4:13:08 PM] Use Address as Offset: UNCHECKED
[11/2/2013 4:13:08 PM] Main (CHECKED): E:\mobile Box\Riff\dump\ZTE\ZTE_S165.bin
[11/2/2013 4:13:08 PM] Redu (UNCHECKED):
[11/2/2013 4:24:36 PM] Open serial port...OK
[11/2/2013 4:24:36 PM] Connecting to the RIFF Box...OK
[11/2/2013 4:24:36 PM] Firmware Version: 1.37, JTAG Manager Version: 1.54
[11/2/2013 4:24:36 PM] Selected Resurrector: [QSC1100 X14 NOR V1.0.0.0]
[11/2/2013 4:24:36 PM] Connecting to the dead body...OK
[11/2/2013 4:24:36 PM] Detected dead body ID: 0x122C80E1 - CORRECT!
[11/2/2013 4:24:36 PM] Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK
[11/2/2013 4:24:36 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX]
[11/2/2013 4:24:36 PM] Settings Code: 0x24010000000000000000000000800000
[11/2/2013 4:24:36 PM] Resurrection sequence started.
[11/2/2013 4:24:36 PM] Establish communication with the phone...OK
[11/2/2013 4:24:36 PM] Initializing internal hardware configuration...OK
[11/2/2013 4:24:36 PM] Uploading resurrector data into memory...OK
[11/2/2013 4:24:36 PM] Starting communication with resurrector...OK
[11/2/2013 4:24:36 PM] Detected an Initialized FLASH1 Chip, ID: 0x0001/0x007E (8MB)
[11/2/2013 4:24:36 PM] Writting FLASH1 memory from 0x000000000000 to 0x0000007FFFFF
[11/2/2013 4:24:36 PM] Completed in 00:11:26.969 (Average Transfer Rate: 11.92 kB/s)
[11/2/2013 4:24:36 PM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] |
