07-26-2013, 10:58 | #1 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Poland
Member: 1343450 Status: Offline Sonork: 100.1581690 Thanks Meter: 1,654 | BTC / LTC Mining using MSM Cloud System BTC & LTC Mining in MSM Cloud System - Beta Don't waste your money if your computers don't have anything to calculate! Now, using MSM, you can extract Bit Coin (BTC), LitleCoin (LTC) or other virtual currency. Version 3.1 does not change anything in SL3 counting process. The changes apply only to BTC / LTC diging and are in BETA version! This update is free for all users at the moment. FAQ: What is Bitcoin - BTC What is Bitcoin - LTC How does it work (in brief):
Use CGMiner application for digging. Sl3 client will start CGMinera will start CGMiner when needed with appropriate parameters. More about CGMiner you will learn here: https://bitcointalk.org/index.php?topic=28402.0 Here, we'll show you how to set PC 2xHD7970 at mine Cointrone and currency Bitcoin:
If everything is set correctly: - GPU usage 99% - (AGV): ~ 1.25Gh / s (2x HD7970 Core 1050 Memory: 900) - HW: 0 After some time, the speed of drone should also appear on the Cointrone site - about 20 minutes. LTC Mining Counting LTC requires different settings than the BTC. In this case, the most important is to set a higher-speed memory - it does not matter if mining BTC. Example drone settings for Cointrone mine, LTC currency and a PC with two HD7970 cards: LTC mine URL: Code: stratum+tcp://coinotron.com:3334 Code: winiu.msm_sample1 Code: msm1234 Code: 1040 Code: 1500 Code: --scrypt --intensity 13,13 --vectors 1,1 --worksize 256,256 --lookup-gap 2,2 --thread-concurrency 8192,8192 --gpu-memdiff 0,0 --gpu-powertune 5,5 --api-port 4028 --expiry 60 --gpu-dyninterval 7 --gpu-platform 0 --gpu-threads 2 Don't forgot set Coin to LTC on Cointrone (or other pool) for this user. More about CGMiner parameters you will find here: Index of /apps/cgminer If everything is ok, CGMiner should show parameters: (PC with 2 cards HD7970: GPU: 1040 Memory: 1500 I: 13) AVG: ~ 1.43 A: should constantly grow R: close to zero, HW: 0. For other graphics cards optimal settings search the LTC or CGMiner forums. Last edited by msm_support; 07-31-2013 at 13:28. |
The Following 11 Users Say Thank You to msm_support For This Useful Post: |
07-27-2013, 08:53 | #11 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Poland Age: 47
Member: 42387 Status: Offline Sonork: 1573735 Thanks Meter: 407 | Quote:
When your PCs haven't queue for counting sl3, SL3Client automatically start digging digital currency, which you can exchange for real money. Otherwise, you mustn't use it, if you want pay electricity cost for all your working pcs, 4 nothing | |
07-29-2013, 05:42 | #14 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
But BitCoins on current BTC level is near to stupid .... | |
