08-03-2013, 09:15 | #31 (permalink) |
No Life Poster Join Date: Apr 2005 Location: X-Sim Philippines
Member: 141973 Status: Offline Sonork: 100.1579084 Thanks Meter: 4,002 | --scrypt --intensity 13,13 --vectors 1,1 --worksize 256,256 --lookup-gap 2,2 --thread-concurrency 8192,8192 --gpu-memdiff 0,0 --gpu-powertune 5,5 --api-port 4028 --expiry 60 --gpu-dyninterval 7 --gpu-platform 0 --gpu-threads 2 not working , if i dont put this on drone settings mining is working ok |
08-05-2013, 13:23 | #32 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Poland
Member: 1343450 Status: Offline Sonork: 100.1581690 Thanks Meter: 1,654 | Start mining ltc ... and when sl3 client take job from server, open job.ini file and start the same from .bat file and then check what is wrong with cgminer senings and corect it on web then. |
The Following User Says Thank You to msm_support For This Useful Post: |
08-05-2013, 13:44 | #33 (permalink) | |
Member: 141973 Status: Offline Sonork: 100.1579084 Thanks Meter: 4,002 | Quote:
the 1st time i try LTC is on 5970x3 maybe extra command not compatible or there something wrong. Br | |
11-29-2013, 11:50 | #38 (permalink) |
Freak Poster Join Date: Jan 2003
Member: 20312 Status: Offline Thanks Meter: 24 | @MSM_Support my pc is 3x7970 , this setings for 2 gpu --scrypt --intensity 13,13 --vectors 1,1 --worksize 256,256 --lookup-gap 2,2 --thread-concurrency 8192,8192 --gpu-memdiff 0,0 --gpu-powertune 5,5 --api-port 4028 --expiry 60 --gpu-dyninterval 7 --gpu-platform 0 --gpu-threads 2 it can run only 2 gpu fine without any errors I cant run the 3 gpu , I try edit and modfay the command but no result . please help , what is the correct command for 3x7970 ? |
12-01-2013, 03:49 | #39 (permalink) |
Member: 1343450 Status: Offline Sonork: 100.1581690 Thanks Meter: 1,654 | Try like this: --gpu-engine 1045 --gpu-memclock 1500 --scrypt --intensity 13 --vectors 1 --worksize 256 --lookup-gap 2 --thread-concurrency 8192 --gpu-memdiff 0 --gpu-powertune 5 --api-port 4028 --expiry 60 --gpu-dyninterval 7 --gpu-platform 0 --gpu-threads 2 |
12-06-2013, 16:31 | #40 (permalink) | |
Br | |
12-16-2013, 12:52 | #41 (permalink) | |
Freak Poster Join Date: May 2005 Location: WGR Age: 38
Member: 142929 Status: Offline Thanks Meter: 7 | Quote:
Maybe MSM support relase suggested setting for litecoin in drone panel? | |
01-12-2014, 16:18 | #42 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Romania
Member: 16269 Status: Offline Sonork: 1604924 Thanks Meter: 62 | why LTC not start ? Code: 19:14:36 Calling home... Success. 19:14:36 Keep counting. 19:14:36 Restarting job... 19:14:36 Starting CGMINER job. 19:14:36 Starting miner... PID: 10700 19:14:36 Done... And counting. 19:14:36 Job exited unexpectedly, waiting 60s. |
01-14-2014, 01:29 | #44 (permalink) | |
Br | |
