If dealer need check imei in the past , If one dealer say not give imei but there imei from them what will u do ?lost time for check pape by page for information right? |
We not work one by one log ,we work by qty so need easy looking for information ,dealer can be mistake with manager qty thx u |
My old distribution system, search engine so nice :) Thanks go to ATF team for amazing gift! This is limition to 10 PC only! ATF NETWORK MASTERCODES |
Hello 2 imei and Hello when i put 2 imei to cloud i get mesage This IMEI is already queued or done on another cloud in our system. Please contact support if you wish to migrate IT. |
Update 23.12.2011
http://winiu.com/support/sl3client/20111223-112655.png ========================= hcloud-drone installation ========================= 1. Place ``hcloud-drone`` and ``config.yml`` in same directory as ``*hashcat-lite*.bin``. 2. Open terminal and run ``hashcat`` manually to accept EULA, e.g.:: oclHashcat-lite32.bin -n 800 -m 1900 -1 00010203040506070809 450CC90B201568478F48A19721811D976A56950C:003573980 418839600 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 After typing ``YES`` press ``q`` to quit hashcat. 3. Register drone by visiting *Drone add URL*. You can check HW Key by runing in terminal:: ./hcloud-drone -w After registering save key into drone config by runing in terminal:: ./hcloud-drone -k KEY (put key generated on register page in place of ``KEY``) Your drone is ready to go, you can run it in terminal:: ./hcloud-drone Reporting bugs -------------- If you wan't to report bug please run drone in debug mode:: ./hcloud-drone -d When reporting errors please atach debug.log and message.log to bug report (zip it or cut file to only last 100 lines or so). Compatibility ------------- If you're able to run hashcat on linux machine, hcloud-drone should work. hcloud-drone was tested on: Ubuntu 10.10 OCL Ubuntu 11.04 CUDA Known issues ------------ At this moment hcloud-drone doesn't report speed to server. It will be added within few days from this release. hcloud-drone must have ifconfig and udevadm installed, as well as physical drive (sda1 or hda1) to guarantee HW Key uniqueness if you're runing diskless cluster, please contact us so we could work it out. |
You still not fix the NCK not generate issue :( Also, is it possible to use in same Cloud both Win and Linux client? |
Just check, not work "Invalid email address" Code: Add multiple e-mail sending, just separate adres ";" when you add hash example: [email protected]; [email protected] |
thanks and good work |
How to buy rapidly sl3 cloud system activation via paypal for 2 pc. Free period end. Br Bpeti |
Supporter Pls check the server ,NCK converting not running ,auto emails system too.Thank you . Merry X'mas guys . |
Today I get some NCK and emails... Email will be not sent if there is no NCK... |
NCK will be calculated ASAP - maybe some technical problem, maybe some limit.. there is Xmas so support do not work I think, when problem will be solved, all NCK will be done - and ONLY when there wll be NCK email can be sent - otherwse email will be not sent. Remeber that You have COD - Yuo can calculate NCK Yourself using any box/dongle... Happy Xmas and New Year to You! |
