Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Martech Products > MSM Service Manager
Old 01-02-2013, 16:34   #406 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
And? People, 0.13 still working perfectly on SL3!!! I know what I'm talking about. And for msm cloud, I've asking to support from 0.10 versions after 'markov'. On future versions SL3 will be dropped.
B.R.
Alkapone
Old 01-03-2013, 04:46   #407 (permalink)
Member: 692006
Sonork: 1592907
Thanks Meter: 8
CL 0.8, 0.09 and 0.10 don't work in 2013 year, and we have already seen
Fix to it is chcange date to 2012 on pc or change OCL exe files.
To make it easy we add option in drones edit tab:
If you check this option and click save (one time). Client on this pc after finish current job will download fixed EXE from server and replace it on pc.
IF you use 0.09 before all will work automatic. If you use older version before you must say YES in EULA window on this pc.
You can do this job for all your PC one time, just click:
Force Hashcat reinstall on all drones
If you upgrade OCL from 0.08 or older check all your pc after that.
Don't forget that OCL0.09 need accept EULA and new drivers.
Old 01-03-2013, 05:04   #408 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 393
Its better add hashcat-lite v0.13 to system, since many willing to use it!
Old 01-03-2013, 10:32   #409 (permalink)
Member: 1809955
Hashcat 0.9 2013
Contacter moi par email je l ai hashcat 0.9 2013
Old 01-03-2013, 10:34   #410 (permalink)
Member: 1809955
Hashcat 0.9 2013
voila mon email ceux qui veut tÚlÚcharger HASHCAT 0.9 2013
[email protected]
Old 01-03-2013, 11:44   #411 (permalink)
Member: 1809955
[email protected]
download HASHCAT 0.9 2013
Old 01-03-2013, 17:00   #412 (permalink)
Nonoyxp's Avatar
Member: 141973
Sonork: 100.1579084
Thanks Meter: 3,997
Originally Posted by Alkapone View Post
If to use 0.13 we have chance to use real random, not 'random' 100>0. Does making patch consumes less time than to add support for new version??
B.R.
Alkapone
whats 0.13? 0.13 working for sl3?
Old 01-03-2013, 17:11   #413 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
Yes, 0.13 is working, further versions will not work thanks to some people. I don't know where was problems in performance and why MSM makes useless programs like for iphone and can not make normal updates for system which was designed for one purpose - be as backend for OclHashcat-lite and it's latest and most improoved version is 0.13 with SL3 support.
B.R.
Alkapone
The Following User Says Thank You to Alkapone For This Useful Post:
Old 01-03-2013, 18:55   #414 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,348
Originally Posted by timex567 View Post
Can you put crack download link so we can test, original link not working
No crack version is not allowed from ocl autor then noone should give link without oclhashcat-lite autor support.
Old 01-05-2013, 04:47   #415 (permalink)
Member: 1754237
Is this still available now?
Old 01-08-2013, 13:03   #416 (permalink)
Member: 151633
Thanks Meter: 12
I try counting 3 different phones today . The counting stopped 1% . Error messeage "Invalid log, can't verify the hash" WTF this error?
I use more than 1 year martech cloud system without any error.
Old 01-08-2013, 13:45   #417 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 393
Move the mouse to done time of that one, will display which PC found that bad code, check that PC --> 100% that PC have problem with VGA card(s)!
Old 01-08-2013, 13:47   #418 (permalink)
jala's Avatar
Member: 17324
Thanks Meter: 40
I had that issue - I have calculate 3 times that hash, and always same result: Invalid log, can't verify the hash in NCK file. always on diferend PC... I dont know why there was that problem.
Old 01-08-2013, 13:51   #419 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 393
To run again, you should delete .cod file (contain bad code from that PC SL3 Client folder first) then re-calc
Old 01-08-2013, 13:56   #420 (permalink)
jala's Avatar
Member: 17324
Thanks Meter: 40
I know... I have calculate it 3 times and alweays same result, always found on ddiferend PC. I have wrote it already
Also cuastomer read hash by other software - same result
Test Card File System??? davieb Motorola Old Legacy (EMMI) 3 05-27-2001 15:21
System connector for Ericsson 7XX cahrisma Sony Ericsson Hardware Repair 4 06-13-2000 09:04
SMS via system connector pasisoft Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-21-1999 11:05
SMS via system connector? pasisoft Old Ericsson Phones & Sony Phones 0 10-19-1999 19:03
Page generated in 0.51222 seconds with 9 queries
